Question about Mitsubishi VS-60707 60" Rear Projection Television
I have a mitsubishi vs60707, the tv works great most of the time. But ever since the power went out at my house, the tv will turn itself off after a few hours of viewing but it does not always happen. If you wait about 15 minutes it will turn back on and work fine.
  • jeffdahms Nov 13, 2010
    i can see one capacitor that is questionable as to wether or not it is bulged. does this unit have a cooling fan or is it just the heat sinks? how can i test the capacitors? would the bad capacitor be warmer than the others?
  • Mitsubishi Master
  • 5,138 Answers
Most of the time Poor Solder connections will be the problem try resoldering the power supply board/deflection board and resolder the STK ICs. while your in the set Look for bad Capacitors
they will be vented or puffed up on top.
Posted on Nov 13, 2010
  • ladywinn
    ladywinn Nov 13, 2010
    Capacitor checker Meter is good to have,or Voltohm Meter but alot of times caps will be Puffed up on Top so you know they are Bad.unsolder the cap and turn it upside down on its top if it isnt Flat as a board then its bad. Capacitor also can be come leaky and no longer hold a charge for circuits to work. Mats Electronics has Nice In- Circuit Capacitor Tester for $49.95
    1-800-628-1118
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
Model vs60707 projection tv. used to turn off when got hot,then turn back on. placed fan in front,would stay on,now hear relay clicking on and off with no powering off.
You will need to replace the STK ICs,they are Big Black ICs and will have Part Number on them STK392-570.
Mats Electronics has Parts 1-800-628-1118
If you are unable to Solder you can ship board for repair to PTS 1-800-844-7871
Jun 29, 2011 | Mitsubishi VS-60707 60" Rear Projection...
My mitsubishi tv vs60707 turns off as soon as I
These are bad about bad capacitors in the power supply and main pcbs. Unless you are good with MAJOR chinese puzzles, leave this one to a pro.
Oct 12, 2009 | Televison & Video
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
Need signal board
u can get the require parts at www.partstore.com just insert the proper model and select the perfect brand in the link and the required part will be shown with its present rate.u can also order from this link.
Jan 06, 2009 | Mitsubishi WS-65819 TV
Mitsibishi vs60707
This a deflection problem. Both 2-3 and 2-4 are deflection. Most likely a verticale problem. a tech will need to fix it.
Mar 15, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv will not turn on but it constantly blinks and will not stop
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Mitsubishi VS-60707 60" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
