Question about Whirlpool Refrigerators
How to remove water filter from the whirlpool estate icebox TS25AFXKQ03
4 Suggested Answers
  • 531 Answers
SOURCE: Whirlpool TS25AFXKQ03 New ice maker installed, but not working
see if the icemaker is on or water is comming throw
Posted on Apr 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: TS25AFXKQ03 whirlpool fridge freezer not working
It is possibly stuck in defrost or the compressor is trying to start but cannot. Are the lights on only? Are the fans running? Your model has a defrost timer inside the fresh food section and behind the control panel. Part number 482493 and there should be a small opening with a plastic plug covering the hole could you remove the plug and with a flathead screwdriver slowly turn the timer clockwise until compressor starts. If this does not work we will need to do some other test. Let me know what you find, Sea Breeze
Posted on Dec 23, 2009
  • 77 Answers
SOURCE: we have an Estate Whirlpool Side by Side Fridge
You have done some good work, and you are right on the money. Yes you need a new filter. There are o-rings that seal on each filter. These wear out but when you replace the filter you naturally get new o-rings and they seal better :) These seals used to be in the housing, but you can see the problem with that. Once those wear out, you have a much worse problem replacing those then with a filter. It's perfect really, you change the filter because you have too, and get a new seal at the same time!
Posted on May 30, 2010
Water leak at bottom of Whirlpool Estate washer.
If it is a top loader, the pump is accessed from the front.
Jan 24, 2015 | Whirlpool Washing Machines
The ice and the cold water have a musty odor
Check if any food may have fallen inside the icebox, like frozen meat. You can also install a filter between the ice maker and the water supply to see if it solves the problem. Good luck!
Aug 04, 2011 | Whirlpool Refrigerators
How do you replace the water inlet valve on the estate by whirlpool
You unplug the machine, turn off water and bleed off pressure, open the wahsing machine case, disconnect water hoses and electrical connections to the valve, and then unscrew the valve's mounting screws.
Oct 03, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
We have an Estate Whirlpool Side by Side Fridge and the water filter is leaking. Should we change the filter? When we remove the filter the dripping stops but as soon as we re-install the filter and twist...
May 30, 2010 | Whirlpool Refrigerators
Whirlpool estate, is no longer cold, for the freezer or icebox
hi,
pull it out and study the back of the fridge down where the cardboard cover is, ((careful of the water line)) sometimes the cardboard cover will come loose and get in the way of the small fan back there, if it does , it will do that, if thats not it, probably your best bet will be to call and have a guy come out and test it. craigslist has cheap side by side fridges, since theyre such a pain to replace..
good luck
J
Jun 26, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool estate washer will not spin
In the front of the machine below the door you have a panel. There are 3 torx screws holding it from under. Unscrew and pull panel down and then towards you. You will see the pump assembly right in the center with big black hoses.
You need a pair of pliers and a shop-vac if you have one, or towels and a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will start to leak out; use towels or shop-vac to mop up. Do this till all water is mopped. Remove the drain trap completely, you will find much junk; clean out completely and refit carefully, in reverse order.
You can rate me……the above is for a similar(?) whirlpool.
Feb 28, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
