Question about Toshiba Satellite Pro L300 Notebook
When i turn on my computer a black screen pops up saying enter current password._ Unable to use f2 or f12 What am I supposeed to do
    Genius:
  • 1,542 Answers
Hi
You could try to start up in safe mode ( quite often f8 ) sign in as administrator and cancel the password
Also if you get into safe mode try a system restore back to when it was ok
Or hit delete key a few times when starting up hopefully this will take you into the bios because the f12 or f2 key may be disabled
Be very careful what you change in your bios because on a laptop its not very easy to change jumpers on bios battery so only enable the f2 or f12 then hit save and exit windows will then restart
But be very very carefull not to play around in the bios if you dont understand it you may end up with BIG BIG Problems
Posted on Nov 13, 2010
Wont run windows at all. Says: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
You have a corrupt registry and it needs to be replaced.
Doing a System Restore will do this. Since you cannot run it from the hard drive, you will have to boot from a Windows DVD.
Here is the procedure
Running System Restore in Windows 7 from your Windows Disk gHacks Tech News
You did not specify which version of Windows you have so I just picked W7 as an example. If you need more specific instructions, you need to give more specific information.
Here is an explanation of System Restore
System Restore Wikipedia
Mar 20, 2017 | Computers & Internet
Tip
For Windows OS PC's
If you have forgotten your password on your PC Desktop Computer, or Laptop:
1. Start (restart) the computer
2. When the computer first starts, look in the lower left corner of the screen and look for two "F" commands. One is F2, the other either F11 or F12.
3. Press the F2 (or F12) to enter the setup configuration. (some are set for either, but only one will take you into setup; it will say on the screen)
4. Once this loads, you'll see a file menu. Using your arrow keys, move through the file menu and use the down arrow key to view the list of options for each, and look for the password reset option.
5. Once you have found this,it will ask for the current password. Leave this blank unless you know or think you know what the old password is (best if you know). The next two lines will ask you to enter, and re-enter the new password. For now, you will want to leave them blank, but select them using the down arrow key, and press enter for each.
6. Scroll to the far right (last menu item) and scroll down to select "exit while saving". The OS will restart and reload the OS. Once prompted for the password, (for windows 7) press enter. If using and older version of windows is being used, you may not be prompted for a password (except windows xp) and the OS will automatically load to the Desktop.
7. If doing this does not work, or if when in setup the old password was deemed incorrect, try another password or leave it blank, select that box, and press enter, as well as for the new password and confirm new password boxes, exit while saving, and restart OS.
Please let me know if you need further assistance. Thank you.
carsandcomps
on Feb 01, 2012 | Computers & Internet
I received a toshiba satellite l305-S5919 laptop as a gift. the first time i turned it off, it's never turned back on. when i turn it on the F1, F2 and F12 keys do not work at all during the 1 second...
This is what we call a BIOS password, I have worked in the PC repair field for years, and this is something that you are simply not able to "crack" or get around. There are a couple things you can try though, if you can find an locate the BIOS BATTERY inside the notebook, you can pull it out, and SOMETIMES it will reset that password....this is very rare, and you only mostly see this is older computers that it actually works. Two questions: Is this used? Is it still under warranty? (check by going to Toshiba.com) Hope this helps!
Aug 03, 2011 | Toshiba Satellite L455D-S5976 Notebook
Have a toshiba c655 & forgot my password / as soon as I turn it on it- says to enter current password. It will not let me use F2 or F12, it goes right back to enter current password. How can I solve...
Have a toshiba c655 brand new in the box as soon as I turn it on it- says to enter current password. It will not let me use F2 or F12, it goes right back to enter current password. How can I solve this problem?
Oct 12, 2010 | Toshiba Computers & Internet
No operating system found
If the error message says "No operating system found" it is most likely a faulty disk controller or a faulty hard disk.
Reseat the hard disk, if this doesn't work you need to test the hard disk another way. Remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer sees this as an external hard drive and you can open the folders and files then the hard disk is OK and the fault is the disk controller on the the 4115c laptop.
If the hard disk is not detected then the hard disk is faulty. You need to install a new hard disk, install Windows and the laptop's device drivers and programs to get a working laptop again.
Sep 11, 2009 | Computers & Internet
Asking for a password without one set
remove the bios battery and start computer. Switch off and replace battery. The password prompt should dissapear after doing the above. Hope this helps.
Dec 03, 2008 | Toshiba Satellite A135-S2246 Notebook
Toshiba Satellite Pro L300 Notebook Logo
454 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
