Question about Sony Cyber-shot DSC-S700 Digital Camera
My USB cable jiggles in the camera port and never makes the full connection when I'm trying to transfer images. It's odd because I barely used the camera to transfer images in the past 3 years. Anyway, is it worth repairing? Thanks.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Consider NOT using the USB connection.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 13, 2011
Stuck in video Mode on startup - Liquid Image VideoMask 310
I realize your post is several months old, but since no one else answered, here goes. With fresh batteries in your camera, attach the USB cable to the mini connection hidden below the screw-on-cover on the top of the camera body. Make sure you have the mini side of the USB cable attached correctly to the camera. Be careful. It will fit both ways but only works for one of them. Don't turn the camera on. Attach the other end of the USB cable to a USB port on your computer. The camera should activate (The LED should come on. Blue first, then red and stay red) and you should see "USB" in the LCD display on the back of the camera. Your computer may indicate new hardware found or may ask you what to do with files on a USB storage drive, which is what the camera will be read as. Do what you need to do to answer your computer so it will recognize the camera. Afterward, you should be able to transfer your memory card contents onto your computer. Once you have confirmed transfer, format the camera storage card so it is empty for the next round of photos/video. Hopefully you have this working by now, but just in case someone else has the same issue.
Jul 30, 2017 | Liquid Image VideoMask Series 310 + 4GB...
I can't download all my images, I have 10 images that will not download. It downloads 52 (1/52 - 52/52) but the camera set up another set of pictures 1/10 - 10/10 that will not download. Can you...
Below is the standard procedure for checking for solutions. If you have a card reader available, I'd recommend removing the memory card from the camera and trying to download the images directly from it.
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Hope this helps.
May 05, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
Computer cannot detect camera, tried different USB cables
is the usb port active still? try wiggling the cable at the camera connection.good luck farr64
Apr 30, 2009 | Cameras
Transfer the photos
This can occur due to 2 reasons..
1) Bad USB port: Try connecting to a different USB port and see if it works. If it does then its probably a problem with the USB cable.
2)Bad USB cable: You can resolve this by Changing the cable or by getting a USB card reader. Specify the details of your Memory card and i will help you find a card readr that suits your card..
Jun 16, 2008 | HP Photosmart R717 Digital Camera
Downloading pictures onto computer
There are Three primary ways to do this...
1. use a (usualy supplied) data cable... normaly a USB cable... it connects to your computer/laptop , Use a Photo utility program to "find" the camera. You should be able to view the pics stored in the camera.
2. If the camera pics are stored on a sim card then simply put that card in a multi card reader... (very inexpensive to purchase and standard on some late model PC's) and in most cases you can pull the pics directly from the card.
3. Take the camera directly to walmart or walgreen's photo station and they usualy can pull the pics directly from it.
give me some more info and I maybe able to give detailed help...
mod# of camera and what model/make of your PC.
Apr 08, 2008 | Computers & Internet
No pictures
Have you checked the HP hep site?
Here is their suggestion
Introduction This document explains how to transfer images from the camera to a computer running Windows XP operating system by using a universal serial bus (USB) cable. Transferring the images Follow the steps below to transfer images from the camera to a Windows XP computer. Step one: Connect the camera to the computer
  1. Turn off the camera.
  2. The camera came with a special USB cable for connecting the camera to a computer. Connect the large end of that USB cable to the computer. Figure 1: Connect the USB cable c00878070.gif
  3. Open the rubber door on the side of the camera and connect the small end of the USB cable to the USB connector on the camera.
Step two: Transfer the images Choose one of the following methods to transfer the image files: Method one: Transfer images with the HP Photosmart software
  1. Make sure the HP Photosmart software is installed on the computer. If the software is loaded, then go to step 2. If the software is not loaded, click here to upgrade to the latest version of imaging and printing software (in English).
  2. If images on the camera are selected for printing or selected for HP Instant Share destinations, make sure the computer is connected to a printer and the Internet.
  3. Turn on the camera. The HP Import Photos software starts on your computer. If you have set the software to automatically transfer the images in the camera, the images automatically transfer to the computer. Otherwise, in the Transfer images from Camera/Card screen, click Start Transfer . The images are transferred to the computer, and then if there are any still images that were previously selected for HP Instant Share destinations, those actions are started.
  4. When the Image Action Summary screen appears on the computer, you can disconnect the camera from the computer.
Method two: Transfer images without the HP Photosmart software If you do not, or cannot, install HP Photosmart Software on your computer, you can still transfer images from the camera to the computer using the Picture Transfer Protocol (PTP) in Windows XP. Follow the steps below to transfer images.
  1. Turn on the camera. Windows will automatically launch a program to transfer the images.
  2. When the images have finished transferring, disconnect the camera from the computer.
  3. If you encounter problems, check that the camera USB Configuration in the Setup Menu is set to Digital Camera .
    1. While in Live View , press the Live View/Playbackc00591915.gif button, and then press the Menu/OKc00280209.gif button.
    2. Scroll to the Setup Menuc00595863.gif using the left/right arrow c00280208.gif buttons.
    3. Use the up/down arrow c00280207.gif buttons to scroll through the Setup Menu to highlight the USB option.
    4. Use the left/right arrow c00280208.gif buttons to change the setting to Digital Camera and then press the Menu/OKc00280209.gif button.
    5. To exit from the Setup Menu , press the Live View/Playbackc00591915.gif button.
  4. Reconnect the camera to the computer.
Mar 06, 2008 | HP Photosmart M415 Digital Camera
Can't transfer video to PC
I could not find the manual for this model on the web, so I'm giving you my best guess.
I found some information that said you could transfer still images and Motion-JPEG video clips to your computer using the USB port.
In general you cannot transfer video to your computer using a USB. To transfer video from most camcorders you need a DV (Firewire, also called 1394) cable. You also need some software.
I'm thinking that when you have an SD card in your camcorder there's some way to tell it you wish to record Motion-JPEG clips to the card rather than full video to the tape. If you've created a standard recording I don't think you'll be able to transfer it with USB.
I believe Windows Movie Maker will let you connect to your camera using a DV cable. I used software called Scenalyzer. A full demo is available free of charge at www.scenalyzer.com. The demo will leave a "watermark" on your video. If you like the software you'll need to buy it in order to capture video without the watermark.
If you have any more questions, let me know.
Dec 28, 2007 | Canon MVX330i Mini DV Digital Camcorder
PC shows no disc in drive E
is this because i used the usb cable for another devide?
- i dont think so. the usb cable that comes with the benQ camera is the usual usb cable. i used it for other devices and still works fine with my camera again. i even used another usb cable from other devices in camera and it works fine.
is it a virus maybe?
- well you can try inserting a different device in that usb port, now if it still cant see it, its probably busted. all your usb ports are on used? wow! how about you try taking some of it out and check those ports for your camera.
Nov 26, 2007 | BenQ DC3410 Digital Camera
Olympus fe-130
Make sure your cable is OK. 1: Make sure you don't have any damaged pins on the plug on your camera and on your USB port on the computer Try using a different cable to be sure that is not the problem. If you can t ry a different camera on the same cable and make it work, your camera is at fault. Try it on a different USB port, and possibly also on a different computer to make sure the port on your computer is not at fault. Check both cable ends and the ports on the camera and computer are not dirty
May 18, 2007 | Olympus FE-130 Digital Camera
Sony Cyber-shot  DSC-S700 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
