Question about Wagner 0513040 Paint Eater
How do you change the disc on the paint eater?
Front wheel bearings
first check the pads have not worn down to metal if they have the disc will have to be replaced , if the disc is in good condition and the pistons are free press them back into the cylinders and then the pads can removed .check the master cylinder does not over flow as the pistons are pushed back. Brake fluid is a paint remover. the wheel bearings don't have to be touched to replace pads. After new pads are fitted the brakes will have pumped to bring the pads out to the disc.
Aug 15, 2014 | Cars & Trucks
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
PAINT BUBBLING ON RHS ENGINE SIDE COVER
if its bubbling and white powder coming out its corrosion and you need to get a drill with a wire brush and a small sander disc to remove the bubbles then primer then paint ! if the paint has bubbled and slight brown discolouring its your engine overheating and needs checking why ! P...
Dec 03, 2013 | 2001 BMW F 650 GS
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
Weed eater one friction disc problem
HOW REPEAR THE FICTION HOB WEED EATER TRACTORS
Aug 22, 2012 | Garden
Can't run hudquarna 125 RJ at high speed?
If that is the only disc that won't run, check disc for scratches, fingerprints, and smudges, clean disc in luke warm water and dry with a soft towel, if this is a new disc return it.
Mar 20, 2012 | Televison & Video
I need to change my rear break pads and also my emergency brake will not dissengage once put on. How do i fix both?
My hyundai had the emergency brake bracket (mounted to the back of the caliper) rust solid. I used rust eater to get it to slightly break loose. I eventually had to replace both calipers. It is a very consistant problem. My new ones need alot of attention now as well I covered them in caliper paint to help with the rusting. The pads are very simple replacement 2 bolts on the back of the caliper. Remove the pads then screw back in the piston with a import tool from any auto parts store put pads back in, put back on the caliper.
Dec 15, 2008 | Hyundai Motor 2002 Elantra
Wagner 0513040 Paint Eater Logo
61 people viewed this question
Top Wagner Tools & Hardware - Others Experts
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
