Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
My dishes are coming out with a white film on them. I have tried adding jet dry but have the same result.
Cloudy or gritty dishes are due to hard water deposits. Starting in summer 2010, many states have passed laws that prohibit phosphates in dishwasher detergent. The phosphates were good at removing hard water deposits. After the law changed, detergents don't work very well anymore. So I created a product that solves the problem. It's all-natural, contains no phosphate, and it works great! It's a powder. You add 1-2 tablespoons to each wash cycle and you use a lot less of your normal detergent. So your cost per wash does not increase. See my website at www.CitriClean.net
Posted on May 07, 2011
Fixed problem after viewing 93 code but now dishes have brown film or white film. Dishes still dried on food. Have a Samsung DMT800RHS. One suggestion was to get phosphorus which is ******* for deterg
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
Nov 06, 2014 | Samsung DMT800RHS Dishwasher
Cloudy dishes
cloudy dishes, white generally means an overdose of salt in the dishwasher, try turning down the salt setting usually set to 4 from factory
Oct 24, 2012 | Bosch Dishwashers
There is a white film left on dishes after the dishwasher is done. I use cascade detergent and jet dry rinse aid
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 23, 2011 | Dishwashers
It is 6 mos old and it leaves the dishes dirty and with a white film on everything. I used jet dry, cascade with no results. what would cause this? it has done this since day one. thanks
heatman101
Feb 23, 2011 | LG LDS4821BB 24 in Builtin Dishwasher
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Rough film on dishes
first clean dw use tang then prime sink and run dw after that cut back on detergant
Jun 06, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
The dishes come out with a white film on them. they are not clean clear dishes, the bowls and glasses have a film. I was using cascade dry soap switched to liquid soap still have the problem. what can I do...
add Jet Dry or some other sheeting agent to the wash. also most pros frown on liquid soap (gel) so try the hard tablets, most have the jet dry built in. This also ensures the correct amount of soap. if this is a new development check the screens on the bottom of the washer under the spray arm and see if they are clogged with food or gunk. sounds like you are not getting a good rinse.
Dec 13, 2009 | Dishwashers
Hi, We have a new whirlpool dishwasher type no. 575-0. GU2275X TVQO. We have not been able to get clean dishes since purchase. Water is hot, everything seems to be operating smoothly. Use the...
I think I can help. We have the same dishwasher and we have very hard water. The dry powder detergents don't work well. We have found Cascade All in One Gel detergent works best and we use only a little; don't go beyond the first mark in the detergent dispenser, regardless what the instructions say. We have found using more of any detergent makes white film. Don't fill up the pre-wash side either. The Cascade All in One Gel does both at one time, so no need to put some in the pre-wash side. Also keep Jet Dry in the rinse dispenser and make sure it is set up higher, turn the arrow to 4. Try that and move up if needed. Next, we put half a cup of white vinegar in the dishwasher, just pour it in the bottom each time, right before we wash the dishes. This works GREAT! We used the white vinegar in on our former dishwasher of 9 years and never had any trouble with any film buildup. The vinegar cuts all the film and makes glasses look terrific.
If you are still are having trouble, cut out the Heated Dry at then end. The heat can cake hard water on your dishes. It may not dry the dishes as well, but it seems to stop any buildup. Using the vinegar though, we use the Heated Dry and still have no film buildup. So for us, we use a small amount of Cascade All in One Gel detergent (buy this basic gel, no added anything), 1/2 cup white vinegar poured in the bottom and Jet Dry in the rinse dispenser. We always have sparkling clean dishes with no hard water buildup. If you don't have real hard water, but just a little hard water, you might try decreasing the white vinegar to 1/4 cup and increase it if you start seeing the white film build back up. Also don't overload the dishwasher. Make sure there is space in-between each dish and have all plates face toward the center.
Make sure you turn your sink faucet on to as hot as you can get it and run the water until it is hot, then turn off the faucet and turn on the dishwasher. This helps to keep the dishwasher from running longer, which would mean more hard water swishing around longer if you don't heat the water, and you know what that means, plus the heating element has to work harder to get the temp up and that makes it burn out quicker. Once a month check your jet sprays, that turn around in your dishwasher, because the little holes can stop up with hard water gunk and this will cause film on your dishes to build up. Take a toothpick and crush the gunk in any holes and make it go out of the holes. Hope this helps you!
Apr 27, 2009 | Dishwashers
Film on dishes and inside dishwasher
Hi debstone
This is a common problem. what you should do first is pick up some GLISTEN and run it through on a full wash with NO dishes. the use electasol POWDER detergent and turn your jet dry down to 1. that should fix your problem. hope this helped
brent
Aug 01, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
108 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
