Question about Home
My grohe automatic 2000 (919 605 MIT BASIC) is leaking. I took it apart and can't figure out what to do next? How do I stop the leak? How do I get the 17 mm bolt holding the flow rate off without destroying the product. Also the mixer is not working very well, the temperature is difficult to control. What do you think it is?
  • 10 Answers
SOURCE: 1989 toyota 3.0v6
Did you check the thermostat? brand new thermostat sometimes went bad too; happen too me once on my 1989 toyota supra....; Check the water pump and hoses. Flush the radiator really good then get 50/50 mix water & coolant;
Posted on Sep 04, 2008
  • 5 Answers
SOURCE: Husqvarna chainsaw bar bolt loose and leaking oil
had same! was set to release the max amount of oil to bar, but the thread is only so long and will drop out of seat, send it for service and note the bar feeder srew, its faster and cheaper! good luck p.s great saw!
Posted on May 08, 2009
mikeTY
  • 8 Answers
SOURCE: put back togather
http://img107.mytextgraphics.com/photolava/2007/11/23/mx5184-48lorgeqx.jpg
check out this link for the spring location
hope this helps :)
Posted on Jun 13, 2009
  • 120 Answers
SOURCE: My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Posted on Jan 20, 2010
packrat1948
  • 528 Answers
SOURCE: we have a Grohe Lady
Take it back apart and check the placement of all the o-rings and or seals.
The low water pressure may be no more then the aerator being dirty where the water comes out of the spout.
Posted on Feb 05, 2011
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Nov 04, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
Grohe soap dispenser 28.857 leaks
Take it apart and clean it. If that doesn't work consider replacing it.
Nov 30, 2013 | Grohe Deluxe L Soap Dispenser Finish:...
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
We have a Grohe Lady Lux Plus kitchen faucet and the water flow is slow on both hot and cold sides. We took the faucet apart to see if there was trash impeding the flow and found nothing. We put the...
Feb 05, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a Grohe shower head that leaks buckets (not an exaggeration). We bought the parts that we were advised to buy from Grohe, but even the professional plumber couldn't stop the leak or install the new...
sounds like you need volume controls lots of grohe fittings are strictly mixing valves not shut offs if this valve use to work then you need to find plumber familiar with grohe
Feb 21, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Soap dispenser leaks
You can fill these 2 ways.You can pull out pump from top,at sink , and squeeze soap in .Or you can unscrew bottle from under sink and fill, I'm thinking that your bottle is loose under sink, or the plastic neck has a hairline crack. Im not real clear on where the soap is comming from.Thankyou.
Dec 11, 2008 | Grohe Satin Nickel Soap Dispenser...
Home Logo
133 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
