Question about Stoves (161221) Heater
Country Stoves Firestar, free standing gas stove. Operates fine manually using the on/off switch. Will not turn on with the thermostat.
  • 6 Answers
Needs to have the thermal pile cleaned I have to do this once a year
Posted on Jan 22, 2011
Old Garland Propane Gas Stoves. Are the pilots today standing or are they electric start?
Most stoves today are electric start. The reason is they are much safer because if the pilot goes out, there is a gas smell which is dangerous. God-Bless!
Sep 08, 2015 | Garland Kitchen Ranges
The pilot light will not remain on I have a Firestar free standing heating stove
You probably have a bad thermal couple. Take out the thermal couple and sand it off. It's that part that the pilot flame is always touching. Usually a pointy silver metal. If sanding doesn't work- replace.
Jan 23, 2012 | Kitchen Ranges
My stoves 500sldm needs a manual. Gas does not shut off when i close the safety lid
the Knobs need to be replaced as there is a tag which operates the shut off. These often get brittle and break off. You can buy the whole set from Espares, very easy to fit.
Oct 02, 2011 | Stoves 500SIDL Gas Kitchen Range
I have a stoves newhome GL616 cooker that just
Hi I have a gl616 cooker when turned on and flame on gas mark 9 the flame dies down then it turns off, any reason why this happens have replaced the fan,problem still occurs.
Jul 06, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
Stoves richmond 1000df - no instructions for which knob operates which oven - dont know how to use slow oven
The book that came with the cooker only explains the symbols on the knobs not which knob to use with what cooker. It is very confusing. Does anyone know where I can get something more comprehensive?
May 14, 2010 | Stoves Richmond RM1000DF Dual Fuel...
Hi i have astoves gas cooker, model 600gdoa and i
Stoves 600GDOa - when the glass lid is lifted to start cooking it turns on (anticlockwise direction) the switch, which turns on the gas - unlit. I wouldn't believe it unless it happened to me. At the moment the switch is taped shut but I would like some ideas.
Mar 16, 2010 | Stoves 600GDOA Gas Kitchen Range
Stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
How to convert from natural gas to propane
All stoves in this country come from the factory with orifices designed to use natural gas. To switch over to propane, the orifices have to be changed over. Contact your propane provider and they will obtain the proper orifices for your range. They may even install them for free. good luck.
Feb 18, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven cooling fan keeps on spinning
Sounds like you have a oven probe or (if equipped) computer issue. From the looks of it, you dont have a computer on this model, so you probably have a thermostat stuck somewhere in there. The thermostat closes at the set temp, then opens when the unit cools. Sounds like this one is stuck in the closed position, allowing the fan to run all the time. You will have to look and see if you have a wiring diagram on the back of the unit, then find the fan wires and see which thermostat controls it. If no diagram, follow the wires out of the fan and see if on runs to a thermostat. Good luck and let me know if you need further info.
Nov 16, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Thermostat + User Manual
The manufacturer, (Stoves), no longer has a web site, so they are most likely no longer in business. However, like most manufacturers, they used parts common to most ranges. If you can extract the part, there should be a replacement part for it at a local parts supplier.
Dec 03, 2007 | Stoves 1000DFDL Dual Fuel (Electric and...
Heating & Cooling Logo
822 people viewed this question
Top Stoves Heating & Cooling Experts
Paul Carew
ghold1
Level 1 Expert
vance jones
Are you a Stoves Heating and Cooling Expert? Answer questions, earn points and help others
