How do you change out electric blower motor on Lifebreath 200 Max
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Need user and operators manual for Lifebreath 200 Std HRV
Try to Google the brand and model number for "manual" to see what comes up.
Posted on Oct 22, 2012
Vw touran heater/fan problems
need to ck the amps a the blower motor posible you have a bad blower motor
Sep 07, 2014 | Volkswagen Touran Cars & Trucks
How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
With Delphi Blower Motor
  1. If equipped, remove the sound insulator panel.
  2. Remove the blower motor insulating cover screws.
  3. Disconnect the electrical connector from the blower motor.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
  6. Remove the blower motor.
With Visteon Blower Motor
  1. Remove the sound insulator panel.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the screws from the blower motor.
  4. Remove the blower motor from the HVAC module.
  5. Remove the retainer from the blower motor wheel. Discard the retainer.
  6. Remove the blower motor wheel from the blower motor.
Jul 27, 2014 | 2001 Chevrolet Silverado
2004 Buick Lesabre blower motor repair
You dont.
Replace the motor.
Buy a good one at Napa or Autozone. Dont buy advance because they have poor quality electrical parts in my experience.
Install new motor. Done.
Mar 14, 2014 | 2004 Buick LeSabre
Want to change fan on blower heater
Removal
  1. Remove wiper arms.
  2. Remove cowl panel.
  3. Disconnect blower motor electrical connector and vent tube.
  4. Remove blower motor retaining screws.
  1. Remove fan retaining nut from blower shaft through plenum opening while holding the fan from the engine compartment.
  2. Remove fan from blower motor while removing blower motor from vehicle.
Installation
  1. Hold fan through plenum opening.
  2. Install blower motor to vehicle while installing fan to blower motor.
  3. Install fan retaining nut to blower motor shaft through plenum opening.
  4. Install blower motor retaining screws.
  5. Connect electrical connector and vent tube.
  6. Install cowl panel.
  7. Install wiper arms.
Aug 13, 2013 | 1991 Oldsmobile Cutlass Ciera
Oct 22, 2012 | Televison & Video
Blower motor on 2000 toyota camry works only on hi settig
Hi!!
The blower motor speeds are ultimately controlled by the Blower Motor Resistor, when the Resistor becomes defective, current goes right thru it and the Blower Motor only operates at max. speed. Replacing the Resistor is a simple task. Locate electrical connector to blower motor, trace back wiring no more than 8" to next plug, The device where the plug is connected to is the Blower Motor Resistor, disconnect plug and remove the two screws, remove and replace Resistor.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 15, 2011 | 1998 Toyota Camry
I need to locate my blower motor resistor on my 1999 S-10. do u know where it is located on my s-10?
The resistor is located under the hood on the passenger side. At the back of the engine compartment you need to locate the airbox it can be identified by a circular piece that's right beside the fender on the firewall (this is your blower motor) to the right if it (looking from the front of the truck) about 4 -6" you will see a wire plug. Unplug this connector and locate the four screws that attach it to the air box. Remove these screws and pull the resistor from the housing.
Hope helps (remember to rate this answer).
Dec 13, 2010 | Chevrolet S 10 Cars & Trucks
How to change blowermotor on 2001 gmc jimmy
Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
To Remove:
  1. Remove the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  5. Disconnect the electrical connector from the blower motor.
  6. Remove the blower motor mounting bolts.
  7. Remove the blower motor insulating cover.
  8. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting bolts.
  3. Connect the electrical connector to the blower motor.
  4. Connect the cooling tube to the blower motor.
  5. Install the rear coolant recovery reservoir mounting stud.
  6. Install the coolant reservoir.
  7. Install the PCM.
W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
To Remove:
  1. Remove the PCM.
  4. Disconnect the electrical connector from the blower motor.
  5. Move the PCM connectors out of the way.
  6. Remove the blower motor access cover screws. CAUTION
    Do not cut any deeper than necessary in order to remove the access cover.
  7. Cut through the access cover on the cut line using a sharp utility knife.
  8. Disconnect the cooling tube from the blower motor.
  9. Remove the blower motor mounting bolts.
  10. Remove the blower motor.
To Install:
  3. Connect the cooling tube to the blower motor.
  4. Install the blower motor access cover.
  5. Install the blower motor access cover retaining screws.
  6. Using black weather-strip adhesive, seal the cut line.
  7. Connect the blower motor electrical connector.
  8. Reposition the PCM connectors.
  9. Install the rear coolant recovery reservoir mounting stud.
  10. Install the coolant reservoir.
  11. Install the PCM.
Dec 08, 2010 | 2001 GMC Jimmy
My AC was first only working at the max setting now not at all
go for the reostat which is all in one with the blower motor ,expensive part though
Jun 03, 2010 | 2002 Pontiac Grand Prix
Blower motor not always working
when wired to the battery it's getting full power.
so if the switch is set to anything but max it won't get full power. does it work on max?
does the fan stop and start over bumps? will it come on if you wiggle the wires? check those.
if there are no loose wires and the fan is not jammed in the heater box try a new motor.
Jun 24, 2009 | 2001 Kia Spectra
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
