Question about HP Computers & Internet
Installed new power supply on hp m470n cannot remember which wires go where HELP
  • HP Master
  • 5,660 Answers
The HP Media Center M470n uses an Asus P4SD-LA motherboard. The HP 'Oxford' version.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00063272&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=392513
I would like you to scroll down to the bottom of the page, for the motherboard illustration, and photo.
These views are of the motherboard without any hardware installed, (NO Processor Ram Memory, graphics card, { IF used}, etc.)
1) Plug in the 20-pin ATX main power cable. Only plugs in one direction. Observe the Lock on the side.
Typical 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
In the illustration the 20-pin ATX main power cable plugs into > ATX Power Connector, shown on the Right side of the motherboard.
In the photo it is the vertical whitish connector, with 20 socket holes. 10 in each column. To the Right of the Ram Memory slots.
2) Plug in the 4-pin ATX +12 Volt power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
NOTE that there are two Yellow wires, and two Black wires. (Yellow is a 12 volt wire. Black is a Ground wire)
In the motherboard illustration, this power cable plugs into the Left side of the motherboard.
To the Left of the diamond shape with, Intel "Breeds Hill" i848p chipset.
It plugs into > ATX12V1
In the motherboard photo, it is the small square whitish connector, with 4 socket holes.
This connector also only plugs in one way. Observe the Lock.
3) Plug in the SATA power cable to the Harddrive, (Only plugs in, in one direction)
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
The SATA power cable has 15 pins. The SATA data cable has 7 pins.
NOTE*
IF, your SATA harddrive has a provision to be able to plug in a SATA power cable, AND a 4-pin Peripheral power cable, ONLY USE THE SATA POWER CABLE!
It will burn up the SATA harddrive if you use both cables.
In some instances the SATA harddrive will run for a while, then one day POOF!
4) Plug the 4-pin standard Peripheral power cable/s into the optical drive/s. (CD/DVD drive/s)
Note the two rounded corners on the cable's connector. This is to line the connector up properly.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(Misnomered as Molex)
Just in case;
The computer case fan plugs into CHA_FAN1 on the motherboard illustration. This connector is to the left of ATX 12V1.
The SATA data cable for the SATA harddrive plugs into one of the two SATA header, (Connectors), down in the bottom Right, of the motherboard illustration.
P31, or P30.
Doesn't matter which one you plug into as BIOS will find it.
The plastic front panel of the computer is the Bezel for HP. When referring to it with a tech, it is the Front Panel.
The area of pins sticking up on the motherboard, that the cables, (Wires) go to from the Front Panel, is the Front Panel header.
Orientation of where the cables (Wires) go, is a Pinout.
If you need the pinout of the Front Panel header, let me know in a Comment.
I have one for the Asus P4SD-LA Yale motherboard, and I think it's the same as the Oxford.
Posted on Nov 13, 2010
  • joecoolvette
    joecoolvette Nov 13, 2010
    The AGP graphics expansion slot can use either AGP 4X, or 8X graphics cards.
  • 2,229 Answers
The large power connector goes onto your motherboard--20 or 24 pin--in the socket provided. It can only go in one way.
There is probably a second connector, a 4-pin--that will plug into the motherboard near the CPU. It, too, can go in only one way.
Other than that, you just have to hook up the power to the hard drive and CD/DVD.
If you have a high-performance video card that has a power connection, it's probably a 6-pin connector.
var fctb_tool=null; function FCTB_Init_1fa6d7a6c9664247a0ca49a75c796f65(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_8ff702f2dff743098e4136310439f4e3(t) { fctb_tool=t; start(fctb_tool); }
Replace power jack
Power supply failures in a HP computer can cause your computer to fail to turn on, to operate erratically or cause certain system components not function.
However, the power supply is one of the easiest parts of a computer to replace.
You don't need any special skills to do this.
If you're nervous about opening up your computer case and potentially damaging a computer component, don't be.
All you are really doing is plugging in power supply cables after securing the power supply.
The process should take 10 minutes maximum.
Shut down your HP computer.
Disconnect the power cable from the power supply on the back of your computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Unscrew the side panel from the back of the case and slide it off.
Newer HP computers may have a case door you can open for access or have access buttons to press.
Look at the back of your HP computer case for a set of four screws near the top of the case. Remove these screws and set them aside.
Carefully slide your power supply out of the mounting brackets and set it on a clean working surface.
Do not disconnect any of the power connectors yet.
Slide your replacement HP power supply into the case and use the mounting screws to attach it to the chassis.
Use your old HP power supply as a guide to connect your new power supply to all the computer components.
Switch the power cables from each device from the old supply to the new supply so you don't miss connecting any cables.
Check that all the components have power cables inserted and the old HP power supply is completely disconnected from the system.
Close the HP computer case and plug the power cable into the new HP power supply.
http://www.fonerbooks.com/r_power.htm
Apr 15, 2014 | HP Hewlett Packard Pavilion Slimline...
How to install power supply
get replacement first
turn off tower
remove all wires and connections
find case screws on back remove and put in a careful place
ground your hands with a strap to chassis
find power supply and trace power cables to board (2 or 3)
remove power cables
remove screws from power supply freeing from chassis
replace with new supply
plug in cables in same place as old one
close chassis
hook up wires to computer
count down from 10(just kidding)
maybe you get lucky
Jun 01, 2012 | HP Pavilion 735n Notebook
Manual for Hp media center model Pcm470n
Here is the website for support for your system:
M470n Support
There are links for manuals, drivers and more.
You might want to save this site in your Favorites for future use.
Thanks for using Fixya. Please take a moment to rate this solution.
Feb 11, 2010 | HP Computers & Internet
How do I replace the power supply?
To install a new power supply, you don't have to send your computer to a specialist; you can install one yourself.
Before You Purchase. You can buy a new power supply from your computer's manufacturer, a computer store, or an independent manufacturer, but first you should examine your current power supply. Check to see if your power supply is AT (Advanced Technology) or ATX (Advanced Technology Extended) style. Your power supply should be labeled AT or ATX, and in the same area, you should see the output voltage in watts (for instance, ATX-250W). Be sure to buy a new power supply with the same or higher wattage as your old power supply. The higher the wattage, the more energy your power supply will provide to your computer. If you're adding additional components to your PC, you should purchase a higher wattage power supply. Furthermore, measure the dimensions of your old power supply, and make sure these measurements are the same as the new power supply you're going to purchase.
Get Started. To replace your old power supply, you'll need a Phillips or flathead screwdriver, a well-lit, low-static area (avoid carpeted areas), small containers (to hold screws or loose parts), and a pen and paper.
Turn off your computer and all the peripherals (such as your monitor, printer, modem, and scanner). Unplug your PC and all the peripherals from their outlets. After that, unplug all peripherals from the back of the computer. Move to a well-lit, static-free area, such as a tile floor or a kitchen table. Remove the computer case or panels to expose the interior of your PC. The power supply is enclosed in a metal box located in the corner of your computer case.
Before you disconnect any wires, be sure to sketch and/or note where and how each of the wires is connected. These notes will help you remember where to plug things in when you install your new power supply. In addition, when you remove any components from your PC, you should put any loose screws or loose parts in separate, labeled containers to keep them safe and organized.
Find the bundle of wires that come out of your power supply. These wires connect to your motherboard and various drives. Follow the wires to their white, plastic connectors and pull each connector until it is free (never pull directly on the wires). Remove all wires from their internal components. You may have to disconnect the on/off switch if the switch is not built onto the power supply. Occasionally, a large bracket secures a computer's power supply. To remove the bracket, loosen the screws and take it out. Now, remove the four screws closest to the outside edge of the computer case. Don't remove the screws that hold in the power supply fan. Carefully lift out your power supply (don't be afraid to pull it out with a little force).
To install your new power supply, you can reverse the actions you took to remove your old one. Put the new power supply in the same place as the old unit, tighten the perimeter screws into place, replace the bracket, and reconnect the on/off switch. Reconnect the wires by following your sketches and/or notes in reverse. If you have any loose wires, bind them together with a twist-tie. Make sure the voltage switch visible on the power supply is set at 120V (120 volts, common in the United States). Replace your computer case/panels. Connect all peripherals and the power cord to the back of your PC. Plug your PC and the peripherals into their respective outlets.
Start It Up. Turn on your computer and monitor. You should hear the normal sounds of a computer powering up, such as the fan and hard drive spinning. If your PC doesn't turn on or if any components in your system don't function, you should turn off your PC and unplug it. Remove the case and check to make sure all the wires are properly connected. Replace the case, plug in your computer, and turn it back on. If you continue to experience problems, contact the power supply's manufacturer or your PC's manufacturer.
Or you can see this :
http://www.hardwaresecrets.com/article/362
Jun 05, 2009 | Dell Dimension 4700C PC Desktop
HP LaserJet 3030, light print with original brand new cartridge, even with the print darkness set to 5 (darkest). Thank you for any tips!
Forget buying a new toner cartridge and don't bother re-installing anything - This is a power supply problem - The electrolytic capacitors fade away after a few years of power on and the high voltage to the printing engine drops too low.I tried a new toner cartridge - no help - re-installed drivers - no help.If you can handle a soldering iron or know a friend who can, replace the following capacitors on the power supply board on the LHS (power cord side). Make sure you use low impedance 105 degree power supply types. Warning - high voltage !!! power cord out and wait 30 minutes before touching anything.
C374 341 503 529 (47uF/35V), C526 (1uf/50V), C506 (0.47uF/35V), C515 (100uf/50V). All the others tested fine in mine. Also make sure you install them the correct way around!
Now I have "black as black can be" prints just like new and I set print density back to 2 not 5 to save toner.
enjoy ;-) - Ray P
Mar 13, 2009 | HP LaserJet Q2612A Printer
Hello, since 1-2 months I bought a new HP Pavilion dv7 Entertainement Laptop. I re-installed vista because I didn't liked the features which were on this Laptop. Then after I installed Vista I remembered...
You need to download the quickplay software here:
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38266.exe
If the button still does not work, you need to do a hardware reset of the buttons. This is done by unplugging the power supply with the laptop off. Press the power on, then pull the battery as soon as the laptop starts to turn on. Put the battery back in and plug in the power supply and power on the laptop.
Jan 04, 2009 | HP Pavilion dv4000 Notebook
HP PC will not turn on.
It sounds that the Power supply Unit is faulty and needs replacement.The ATX powersupply is easy to replace. you can do it yourself. Just remember how you take it out is how you're gonna install a new one back, remember where the connectors go on the mother board. Remove PC from power mains before you work on the PC. Before you touch the inside of the PC just touch the frame of the PC to ground your self to avoid static. Good luck.
Nov 18, 2008 | HP Pavilion Replacement 200w Micro ATX PS3...
Power supply
all your plugs will only fit into 1 thing i.e. you cant connect a usb device into an ethernet port
or go to www.hp.com/ enter your model number and either choose to download the manuals or talk to hp chat
Dec 08, 2007 | Computers & Internet
Hp media center m470n live tv/radio won't run
Hi Par37ron,
Select Start>Run (in Windows) and type in the following:
dvdupgrd /detect
This will tell you what DVD decoders are installed on your system. MCE2005
needs a newer decoder than other versions of MCE - try:
http://www.intervideo.com/jsp/WinDVD_Download.jsp
http://www.nvidia.com/object/dvd_decoder.html
Oct 19, 2007 | Computers & Internet
Computers & Internet Logo
255 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
