Question about Peg Perego John Deere Gator HPX Ride on Toy
Left wheel only moves in first gear and reverse. right wheel motor heats up also. will not move at all in 2nd gear. is it a switch or motor problem?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You have a bad motor, you can order a new one here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
espressonist
  • 1711 Answers
SOURCE: I have a John Deere
From your description the problem is a motor problem. You should turn the wheel manually and is it can rotate freely, if not then the motor is stuck and you can check the ball bearing if it is rusty or dirty or both and this can make it hard to rotate and that is why it become warm.
Posted on Nov 13, 2010
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
Someone wanting to buy my 1987 ford bronco2 4x4 test drove it and brought it back towing it behind a pu. my sons have driven it for 6 years and no recent problems. we have never used the four wheel drive....
it sounds like the transfer case is stuck in neutral you may have to get under vehicle and block wheels and have some one move 4 wheel drive lever while watching it from under vehicle see if it is moving the shaft on transfer case if it is not repair it possible loose nut or pulled out of plastic grommet if it has an electric motor to move it from 2 wheel to four wheel remove motor and manually move shaft to get it out of neutral if it does replace electric motor
Aug 17, 2013 | 1987 Ford Bronco II
Only 1 wheel turns in 2nd nothing in 1st or reverse
you have a bad motor, whichever side isn't turning you need to replace that motor
Jun 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Front wheel gear not engaging
move wheels out to meet gear if gears stripped switch wheels from front to back
May 05, 2012 | Pentair White/Gray Legend Platinum...
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
124 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
