Question about Kenmore 15516 Mechanical Sewing Machine
How do you reassemble a shuttle hook? Send picture
Page 70 in the manual. You can get the manual at the below site.
http://www.managemylife.com/mmh/owner_manuals/9123/KENMORE-Mechanical-Sewing-L0306419?brand_name_search=38515516000+KENMORE
Posted on Nov 24, 2010
How do I time a bobbin hook on a 153W Singer
all sewing machines are basically the same, the hook that rotates to pick the cotton up off the needle must just enter behind the needle when it's on it's way back up which then grabs the cotton to form the stitch, so you must remove the sole plate to expose the shuttle case remove the shuttle and put to one side, now rotate the hand wheel on the sewing machine in the correct rotation and watch the hook rotate round until it goes behind the needle, just as the needle is starting back up from it's lowest position the hook should just be going behind the needle to pick up the cotton, if this is not the case then loosen the screws that clamp the hook assembly to the shaft and rotate the hook assembly gently until the hook is just going behind the needle and make sure the hook is close to the needle before retightening the clamping crews , and final give it a few turns by hand to make sure the hook locates the same all the time and the hook is not catching the needle, when your happy, then reassemble.
Happy sewing
Feb 16, 2015 | Singer Sewing Machines
How do I reassemble shuttle hook on euro pro sewing machine
Typically, they go together like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
May 08, 2014 | Euro-Pro Sewing Machines
WHERE CAN I FIND THE SHUTTLE HOOK FOR MY LS2125
try these sites--you may have to email them about the part
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
May 08, 2012 | Brother LS-2125 Mechanical Sewing Machine
Brother 1120 sewing machine timing adjustment
Easy to do remove sole plate remove shuttle and case, don't forget to pull the spring loaded plate to one side by inserting a electrical screw driver in the slot and twisting it anticlockwise to release the case, remove drive dogs this will the expose the cotton pickup assembly turn the hand wheel anticlockwise until the hook gets close to the needle now watch the needle it should be in the lowest position and just as it starts it's way back up the hook should be just going behind the needle to pick up the tread if this is not the case and it's out of position then hold the hand wheel tight and insert a small screw driver into one of the gaps in the base were the shuttle case fits in away that you are able to move the hook assembly one way or the other with a gentle pressure and move the hook just to make it enter just behind the needle as it only just starts it's way up at this position it is now complete and you can reassemble and run slowly at first just to make sure things are okay.
Happy Sewing
Oct 15, 2011 | Singer 1120 Mechanical Sewing Machine
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
Piece where the bobbin goes came out, how do I put it back in. I can't find my manuel to see a picture.
General guidelines as you did not specify the make or model:If a front loading bobbin, tilt machine slightly on its back....insert the hook neatly in the shuttle opposite the half moon shaped shuttle..... the ring holding the hook has a small pin that locates it in the main surrounding housing like a keystone. There are two lugs to hold everything in place
If top loading bobbin, the "cow horns" go to the rear to allow the needle to operate and a small lug (front) acts with a stopper atop the hookrace.
Aug 30, 2009 | Sewing Machines
Feels like it seized up. Turns hard
You could have some cotton wrapped around your take-up arm. If you remove the cotton it should go again.
It could be needing oil on the upper shaft bush close to your flywheel. Maybey a drop of oil behind your bobbin case.
Does that model have a plastic or metal Bobbin case?
Jun 23, 2009 | Elna Quilter's Dream 6003Q
Can't reassemble the shuttle/hook in Singer sewing machine - it is Model # 1120 - an inexpensive machine but works great. It jammed and I released the retaining clamps (?) and the other little parts fell...
Turn the hand wheel until the hook race is in the left position..replace the hook to right side...replace the hook race cover..smooth end to the bottom..and snap back the hook retaining arms...now ready for inserting bobbin case...Good Luck
May 29, 2009 | Singer 1120 Mechanical Sewing Machine
Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Mar 16, 2009 | Baby Lock BL1556
Kenmore 15516 Mechanical Sewing Machine Logo
210 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
