Question about ViewSonic VX910 19" LCD Monitor
VX924 - powers on steady green with display illuminated but lasting only 2 seconds then black. I have changed all the electrolytic caps even the large one on board type FSP035-1p101 P/N3BS006431 but problem persists. When I shine a torch onto the screen I can see the display albeit faintly so I presume the logic board itself is OK (no sign of suspect caps) so what else could I change on the power/inverter board? I assume the backlights themselves are OK as the display does illuminate albeit for 2 seconds.
  • admin29429 Nov 13, 2010
    Thanks for the prompt response - I'll give it a go, but do you think there would be such a heat build up in the two seconds from power on from cold to black display to give this problem? i was wondering if there was a problem with one or more of the ceramic capacitors, diodes, resistors or transistors on the board? Is a spec available for the various components on the board so that if needed and where possible I can test first and then replace? as i would rather solder once rather than keep removing the board.
    Keith
    Thanks. Can you say what ics stands for? - is that the integrated circuits on the PCB board itself? I am happy with the power supply as all of my other IT kit is OK.
    Keith
    President:
  • 1,851 Answers
Since you have already changed all the electrolytic capacitors, the next step is to fix the connections that the metallic surfaces used for heatsinks have to do. Locate one by one these metallic heatsinks, turn the board upside - down and use a simple isolated cable to join the copper points that the heatsink connects using a soldering tool. At many cases these connections are very unstable since the heatsinks are getting hot. Use pieces of cables to make these connections secure.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Nov 13, 2010
  • Stelios
    Stelios Nov 13, 2010
    Since you have already replaced all the el. capacitors, the posible problems could be: heatsinks - shortcircuits, ics and transistors. At most of the cases that came to my lab the problem was at the capacitors, or cold contacts on the board; never at the ceramic caps, never at the resistors (by the way check in case there are some power resistors). Another one possibility is the power supply itself, if it's an external one, but this is easily to be measured, on load.
    I'll try to lacate a schematic at my data in order to post you back, but I don't think you'll need this.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    I've never came up with a faulty ic (integrated circuit). I don't think that you will be more lucky that I am...
    In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer, I'll be on line for 2 more hours.
    Thanks and regards
    Stelios
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
2001fp the screen is black the power light is green. It will flash when first turned on but wont light up. I have it apart and I don't see any obvious bad caps
The problem can be in the inverter board: http://www.lcdrepair.us/2001FP-INVERTER.html
You can try replacing the inverter and hope that the problem is not in the backlight assemblies. You need the test lamps to verify the function of the inverter board. Do you get steady 20vdc feeding the inverter. You can also try heating up the two black electrolytic caps on the inverter board to see if the inverter will fire up using hair dryer, when bad caps with high ESR are heat up the ESR will go down.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 11, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Blinking On/Off.. seems to be a common problem.
I just replaced ALL of the Electrolytic Capacitors (6 in all) on my bad VX924 P/S, and it did not help. Several of the old caps were puffed-up/burst. I am ordering a new power MOSFET, Q320, if successful I'll be back in touch.
Mar 30, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Black screen after 1/2 second power-up of Sony SDM-HS73
bratty, do you have a pic on which capacitor this is? Also where I can find a replacement one.
My monitor is doing the same thing, nice and bright for 1/2 a sec then goes super dull, you can barley see anything.
Thanks,
Jake
Oct 01, 2007 | Sony SDM-HS73P 17" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down.?
Well with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe..
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Sceptre LCD - no display
There is 2 caps in the power supply that are blown I have fixed 15 of these LCD with the same problem.
Mar 10, 2006 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
ViewSonic VX910 19" LCD Monitor Logo
165 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
