Question about Denon AVR-1508 Receiver
No sound out of center channel denon avr 1508
  • scott_r_jeff Nov 14, 2010
    thanks for the suggestions, but this is well beyond any of that. i've done a hard reset as well. i assume i've got an internal issue.
  • Denon Master
  • 6,993 Answers
The problem is either from the center channel fuse, or the center channel output has gotten burnt.
Get a screw driver, open the receiver cover, check the center channel part, check if you will see any blown fuse. If you don't see then it means the center channel output is defective and needs to be fixed.
If you have idea about electronics repairs, you can change the output or read it with a meter and replace any bad component.
But if you don't know about electronic repairs, then you will have to take the receiver to the nearest repairman to fix it for you.
Please do not temper with the unit if you are not familiar with electronic repairs.
Good luck.
Posted on Nov 15, 2010
Check the speaker wire connections. Unplug everything and then plug it all back into the correct jacks. There is an input button on the front of the receiver. Make sure for each source you have the right input selected, ie: digital, analog
Posted on Nov 14, 2010
2 Suggested Answers
  • 119 Answers
SOURCE: Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Posted on Mar 03, 2009
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
Denon AVR 1508 distortion on left channels
I have a different model, but sometimes suffer this when power outages or other strange things happen. Its usually the microprocessor getting confused and not doing its job properly, once none of the speakers came on at atll!
In the handbook, it will tell you how to do a factory reset - that always sorts mine (Same brand, Denon). Just a pain setting it all up again.
You should be able to find a PDF version of the handbook online if your's is misplaced in the house move.
Dec 17, 2013 | Audio Players & Recorders
Only red light is blinking on my denon avr 1508
It sounds like you overloaded the Denon avr with too much resistence from the speakers. Please check the total resistence of the speakers before you connect them all. Also check that the speakers or their wires are not shorted!
Jan 20, 2013 | Denon Audio Players & Recorders
I lost the sound on my denen avr-1508 receiver
You may reset your unit to factory default settings. Check user manual.
Oct 20, 2011 | Denon AVR-1508 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
I want to get full surround sound out of my Denon AVR-1508 w/sub
hi there might be some problem with the link that u have hooked up with the speakers.
Jan 18, 2009 | Denon AVR-1508 Receiver
Sep 24, 2008 | Denon AVR-1506 Receiver
Denon AVR-1508 Receiver Logo
254 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
