Question about Brother IntelliFax-2820 Laser Fax
Printing black shaded on complete page
Printer printing black shaded on complete page in self test and interface printing
All prints are completely black. printer jammed and is now printing black pages
    President:
  • 1,257 Answers
Shading May Print As Black Printing to Fax Printer
CAUSE:
loadTOCNode(1, 'cause')This problem is caused by the Intensity level for the fax printer being set to its default value. This default value does not take shading into consideration.
RESOLUTION :
loadTOCNode(1, 'resolution'); A workaround for this problem is to change the Intensity setting on the Printer Properties page for the fax printer on the client workstation. Select the Graphics tab of the Printer Properties setting, and change the value for Intensity to 125 or more until the shading is the desired tint.
Posted on Jun 18, 2008
    Master:
    Sergeant:
  • 462 Answers
We will reply u soon...
2 Suggested Answers
Logjam
  • 159 Answers
SOURCE: printing black shaded on complete page
Problem is usually a dirty charge corona wire. There is a cleaner on the drum unit, slide this across and back 2 or 3 times. If not, then the corona wire itself is missing or broken, change drum.
Posted on Feb 27, 2008
HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
Dec 11, 2012 | HP Inkjet 1200dn Printer
HP 6940 print head jammed.resume light flashing
Welcome to FixYa!
Usually print head/carriage jam is caused by paper jams or previously cleared out paper jams that left a small torn paper inside the printer.
Turn off the printer by pressing and releasing the power button.
After the printer turns off, press the power button to turn the printer on again.
The printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolved. (See instructions at the end of this article on how to print a self-test page.)
If the printer does not turn off, clear any paper jam. Press the resume button on the printer front panel. If the paper jam does not clear, continue with this procedure.
Leave the printer turned on, disconnect the power cable from the printer, and then disconnect the USB cable from the back of the printer.
Push the two latch handles on the rear access door of the printer toward each other, and then remove the door. Please refer to the image below.
Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Remove the paper carefully. It is possible to damage the printer when removing paper from the front of the printer.
Reconnect only the power cable. If the printer does not automatically turn on, turn it on by pressing the power button.
Again, the printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
If the Power light is blinking and the print carriage is still in a stalled position, continue with this procedure.
With the printer turned on, open the printer cover. The print carriage might move into the access area automatically. Allow it to move to that position.
If the print carriage does not move automatically into the access area, turn off the printer by pressing the power button.
Disconnect the power cord from the back of the printer.
Looking in through either the ink cartridge access door or the output paper tray, make sure that no obstructions under or around the print carriage are blocking it from moving.
Make sure that the print carriage can move freely across the width of the printer by gently pushing the print carriage to the left and then to the right. Clear any obstructions.
Remove and reinstall the print cartridges. Make sure that it is properly installed back.
Close the printer cover and connect back the power cord.
Print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
To print a self-test page, make sure the printer is turned on. The USB cable of the printer to the computer must be disconnected to make sure that we are isolating the printer problem.
Press and hold the Print and Cancel button at the same time. Make sure that the printer is loaded with paper. The self-test page will like the image below.
Keep me posted of your developments.
Thank you for using FixYa.
Jas247
Mar 03, 2011 | HP Deskjet 6940 InkJet Printer
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
The paper is not feeding properly on my printer.As it advances the paper crumples or tilts at an angle and then just stops. A paper jam message appears. Solution Attempts. 1. I turn the machine...
Most of Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper jams to sides on x5470
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
Apr 13, 2009 | Lexmark X75 All-In-One InkJet Printer
Printer won't print...there was a paper jam and it was cleared
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
I just purchased a new lexmark x3550 all in one printer and i began the installation,and when the allignment portion of the installation came the paper keep jamming tried again and the same thing happened....
1. Press the “Settings” button once. The screen with read “Settings: Maintenance”.
2. Press the check button once. The screen with read “Maintenance: Ink Levels”.
3. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
4. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
Apr 10, 2009 | Office Equipment & Supplies
Feb 19, 2008 | Brother IntelliFax-2820 Laser Fax
Shades of gray printing as brown
does the black do a complete nozzle test print.if not clean several times and try nozzle test again
Dec 26, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
I assume you mean the pages are coming out dirty or gary versus white and black text.
change the drum/cartridge, if you get the same results it could be the hi-voltage power supply. most common is the drum.
Dec 13, 2007 | Brother HL 1430 Laser Printer
Brother IntelliFax-2820 Laser Fax Logo
611 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
