Where can I buy an on/off switch for a model FZL4004A wall mounted Fahrenheat heater?
Buffalo12980
  • 625 Answers
SOURCE: Fahrenheat 4000 watt wall mounted heater shuts off and needs reset
the reset is probably an inline circuit breaker. if you can get hold of am amprobe clamp around ammeter, check the current when the unit is running at full power. the reading you get check against the current rating of the inline breaker. your fan motor bearings may be dry increasing the current draw of the unit and tripping the breaker. try oiling the fan bearings with a light oil NOT WD-40.
Posted on Dec 07, 2007
Buffalo12980
  • 625 Answers
SOURCE: fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
Buffalo12980
  • 625 Answers
SOURCE: Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Posted on Dec 14, 2007
Accurate Joe
  • 61 Answers
SOURCE: add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Posted on Nov 30, 2008
budmrtn
  • 11361 Answers
SOURCE: Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Posted on Dec 18, 2009
Do you have a thermostat switch for sale the # on it is L1345F
Hi, Nothing is sold here...
Here is a tip that wrote about how to buy heating and air conditioning partsonline.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Apr 24, 2011 | Fahrenheat VFK404 Electric Wall Mounted...
Where can i buy a thermostat for my heater fhu5-4b part # 5813-2050-000 Thanks Tom
Northern Tool sells ceiling mount Fahrenheat Heaters Try them, they may have it as an accessory or optional item.
Feb 09, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
Looking for bimetalic thermostat switch for the 5000 watt Fahrenheat ceiling mount heater. do you have a parts source?
My place of choice when purchasing for the warehouse is Grainger, if you have one close by. They usually have these items in stock or will get them for you quickly. Give them a try.
Dec 22, 2010 | Fahrenheat Ceiling-Mount Industrial Heater...
I have a fahrenheat wall mounted heater, 120 v model,(can't find a model number on the unit) with a dial temp control. No matter which number setting it is on, the unit cycles off after about 50 seconds....
UNIT SOUNDS LIKE ITS SHUTTING DOWN ON A LIMIT SWITCH IN HEATER. THEY LOOK LIKE ROUND BUTTONS OF DIFFERENT SIZES. THE HAVE 2 WIRES GOING TO THEM AND THEY ARE A NORMALLY CLOSED. THERE IS A FAN DISK NORMALLY OPEN TO UNTILL IT GETS HOT AND CLOSES TO TURN ON FAN.  IF THE FAN SWITCH TAKES TO LONG TO CLOSE THEN LIMIT OPENS TO PROTECT FROM OVER-HEATING
Apr 23, 2010 | Fahrenheat (FFH1614) Wall Mounted Panel...
Wall mount Heather no heating
check the breaker is not blown. if it is reset it. if you have the electrical knowledge see if you have 240 volts at the heater.
Jan 29, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Installation of Fahrenheat wall heater
http://www.marleymeh.com/develop/prod_pdf/instructs/5200-2638-000.pdf
Jan 20, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Electric wall mounted heater
Make sure that the heater is mounted where convection currents occur freely. When heat builds up around the top of the heater its temperature will rise uncontrollably. You'll be luck not to get a fire.
Jan 18, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Fahrenheat wall unit
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
Dec 06, 2007 | Fahrenheat (FFH1614) Wall Mounted Panel...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
