Question about HP Pavilion A820n (PP165AA) PC Desktop
Hp pavilion a820n will not turn on, however, the green light on the back is lit
  • perry_moore Dec 18, 2010
    Could you please tell me the proper procedure for using a jumper wire to test the power on switch on the Hp pavilion a 820n? Thank you
  • HP Master
  • 5,660 Answers
Agree,
1) Could be a bad Power Cord
2) Could be that the inside of the computer is dirty. (Power UNPLUGGED from computer. Observe Anti-Static Precautions)
3) Could be a bad Power On switch, or a bad Power Supply.
There is a test to see if it's the switch, or the Power Supply, if you wish to know.
(The Power On switch is located inside the plastic Power On button, in the Front Panel. {HP term > Bezel}
This generic ATX power on switch I have found, fit's many computers,
http://www.directron.com/atxswitch.html )
The test involves bypassing the Power On switch.
IF when bypassing, the Power Supply comes on, the problem is the Power On switch.
IF when bypassing, the Power Supply does Not come on, the problem is the Power Supply.
The test does not directly involve the Power On switch. A jumper wire is used on the 24-pin ATX main power cable's connector,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00300046&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=443070
Scroll down the page to the motherboard illustration, and photo.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The jumper wire goes from the Green wire, (Soft Power On. Also abbreviated as PS_ON), to ANY Black wire.
ALL Black wires are ground wires.
There is a proper procedure for this, and it does Not involve any splicing, or cutting of wires.
Post in a Comment if you wish to know how.
If the Power Supply is found to be bad, just replace it. YOU yourself can do it.
I can guide you.
Posted on Nov 13, 2010
  • 18 Answers
I have the same model computer and had the same issue. There are a couple of things to check out with both being fairly simple. If possible go ahead and replace the power cord just making sure to replace it with a cord of the same specs which could come from another device such as a printer. The next area to check out is inside the case and here you just want to remove any dust build up and make sure to clean the fan at the power supply. To open the case you only need to remove the two thumb screws on the back side opposite the power cord then pull the side towards you and it will pop off. To clean it you can use a can of compressed air to blow it out, there really shouldn't be any need to disconnect or remove anything. This should prevent it from shutting down and not powering up.
Motherboard replace processor cpu i have an hp pavilion a820n tower with no cpu or power supply can u tell me what kind i need?
the processor to fit the mobo is a pentium 4 socket 775. the original was a 3.2G according to the HP website.
most standard 500 watt power supplies should fit.
it does concern me why there is no processor or power supply in it though.
are you sure the mobo is ok? the only reason I would think these parts have been removed is because the mobo is dead and they've been transplanted into something else.
May 11, 2014 | HP Pavilion A820n (PP165AA) PC Desktop
Green light on my power supply stays lit after unplugging
Usually the light will time out after the capacitor has drained. Your machine is getting a bit old , your PSU may be the problem. If you plug it in and push the on/off button and it blinks, fans spin and shuts down, it's most likely the PSU. Look for a in-line fuse on the Motherboard, if blown, replace. Look at the motherboard closely for damaged components, capacitors, etc.
Jan 27, 2013 | HP Pavilion A820n (PP165AA) PC Desktop
Green light on back of hewit packard goes dim whenever the power button is pushed and the computer will not power up or show any signs of life. I did a voltage test with a voltmeter and all voltages seemed...
try to open your pc..remove your 128mb card then put it back before you put it back clean the pins of it by an eraser the put it back..try to open again your pc..or check your power supply if it is function orderly..
Oct 11, 2011 | HP Pavilion A820n (PP165AA) PC Desktop
My HP Pavilion a820n pc desktop fan runs constantly. I don't think it always ran this much. Previously ran then shut off then ran. We vacuumed the visible dust. Does this signal a problem? Thank you. ...
Fan is inteligent, has sensor when cooldown is reached auto slow down to fix needs to be replaced,will not hurt anything system running cooler is always a good thing i would run it till it dies unless noise is an issue
Jan 20, 2011 | HP Pavilion A820n (PP165AA) PC Desktop
Does not power on, but get a green blinking light at the reap of computer. I think its my power supply. what do you think?
do you try to check your power supply? try to other pc if it is your power supply because if it is the result is the same problem to other pc you tested it is your power supply. But try first to check your memory card to remove and put it again then restart it to open.
Aug 11, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
Hp pavilion a820n comp won,t turn on . rear power light blinking , turned all power off several times waited long intervals before repowering unplug all plugs and tried still no power up found when mother...
make sure nothing is plugged in to your front card readers slots:
If so PC will not boot. Other then that can you put a different power supply in it? Just to see if it is the Power supply..
Jul 26, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
I have a hp pavillion a820n..i was watching youtube quickplaylist 1 day.Then the comp froze. I turned it off,and ever since havent been able to turn it back on.. I tried unplugging power cord and surge...
Check the cable going to your monitor and from the monitor going to the back of your computer, take it out and put it back in. Check also the power cable of your monitor.
Jun 02, 2009 | Computers & Internet
Computer wont turn on
taking out the battery resets the settings on the bios for the motherboard.
worked for me on the few computers that wont turn on.
If it starts up, you may need to enter dates etc onto the bios.
May 29, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Green power supply light blinking? HP Pavilion a820n
These wires vary based on the type of the board each wire lead is labeled to coorespond with the pins on the board. You need to reference the manual for your specific motherboard. If you don't have the original get it from the vendor support site or just google it. Unless your motherboard is an odd brand it should be easy to find.
Mar 28, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
HP Pavilion A820n (PP165AA) PC Desktop Logo
454 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
