Question about Apple iPhone Smartphone
My iphone has the image of connecting to itunes when i turn it on, otherwise than that, it turns itself off again. What do i do?
  • 3 Answers
This can happen if the operating system (iOS) gets screwed up on the phone - it happened to me. Don't panic - you can restore the iphone to working order. You need to use iTunes to restore it - use the "Restore" function and iTunes will send a fresh/updated copy of the firmware to the phone. The process can wipe all the stuff you had on the phone (apps, contacts etc) so then you need to copy/sync them again using iTunes after the restore.
Hope this helps!
Cheers,
DaveK
Posted on Nov 14, 2010
Just got iphone back it says its diabled but for 23,685,670 minutes?
How to fix it if your iPhone is disabled?
If your iPhone is disabled and has to be connected to iTunes, you can connect it to an authorized computer, and the Enter Passcode window will show again. If you insert the right passcode this time, your iPhone will be all right again.
If you forget the passcode completely, I'm afraid that the only way to make it back to work is to reinstall.
Note, that the iPhone will erase itself after ten incorrect password attempts in a row. You can turn this off under Settings > General > Passcode Lock.
6 attempts: 1 minute
7 attempts: 5 minutes
8 attempts: 15 minutes
9 attempts: 1 hour
10 attempts: Erase data. If that option is off it will require connecting to iTunes to unlock.
Mar 04, 2015 | Apple iPhone 4S
Cant update my iphone 4 (model mc609ll )
Perform a recovery-mode restoreIf your iPhone, iPad, or iPod touch is already showing the "Connect to iTunes" screen, please go to step 5.
  1. Connect your USB cable to your computer but not to the iPhone, iPad, or iPod touch until step 3.
  2. Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to turn off.
    • If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
  3. While pressing and holding the Home button down, connect the USB cable to the iPhone, iPad, or iPod touch. The device should turn on.
  4. Continue holding the Home button until you see the Connect to iTunes screen. When this screen appears, you can release the Home button:
    Note:
    If the image of a battery appears, let the device charge for at least ten minutes to ensure that the battery has some charge, and then start with step 2 again. If you don't see the Connect to iTunes screen, try these steps 1 through 4 again.
  5. iTunes should automatically open and display the following message:
    [img alt="Alert text: "iTunes has detected an iPhone in recovery mode..."" width="520" height="241" src="http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1808/HT1808--recovery_alert-002-en.png" data-hires="true">
    "iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes."
    If iTunes not open after two minutes, please open iTunes yourself.
  6. Use iTunes to restore the device.
Sep 21, 2013 | Apple iPhone 4 Black Smartphone
My iphone is saying iphone disabled, connect to itunes and when i connected itunes did not discover the iphone
Try doing a hard reset by holding down the lock button and the home button at the same time until the phone turns off. Wait 20 seconds, then turn the phone back on and try again.
Apr 28, 2011 | Apple iPhone Smartphone
IPhone 2g will not boot to Apple logo or turn on.
Hi
Have you tried holding the power button and the home button on the front for around 10secs?
Try this, the Apple logo should appear and get the phone to boot up.
If that doesnt work, boot up your computer and make sure you have the most recent version of itunes on it and then hold down the home button on the front of the phone while plugging into your computer and keep holding down the home button until you get a message on itunes saying an iphone has been detected in recovery mode. Then release the button and restore your iphone as a new iphone
**** Because your phone wont power on and it has been restarted this way you need to restore as a new iphone to get it to work again meaning you will loose any info on the phone ****
Make sure you update your phones software its most likely a factor to your phone shutting itself down.
Ive put the details below on how to restore your iphone, while restoring it will automatically update it for you - (after holding the home button and receiving the message on itunes follow the restore info)
Hope this helps :0) - Please Leave Me Feedback
  1. Select the Restore option.
  2. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  3. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  4. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  5. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
Select set up as a new iPhone :0)
Jan 04, 2011 | Apple iPhone Smartphone
My iphone wont turn on , what will i do
put it in recovery mode
then restore it
here's how to be in recover mode:
Disconnect your iPhone and turn it off by holding the "Sleep/Wake" button for about five seconds and then sliding the red slider. If your iPhone is already off, there's no need to turn it on and then off again. Once it's off, press and hold the "Home" button and plug your iPhone into a Mac or PC with iTunes installed. Keep holding the "Home" button until you see a dock cable pointing to the iTunes icon. iPhones running older software will display a yellow triangle and text which says "Please Connect to iTunes". Once you see this image, you can release the Home button.
iphone_recovery_mode.jpg iPhone in Recovery Mode
Open iTunes (if it's not already open) and you will be told that "iTunes has detected an iPhone in recovery mode." Click "OK" and you will be taken to the iPhone pane. Click "Restore" and you're done, it's that easy! Depending on the extent of your iPhone's ills, it may take some time to do a full restore. Once you're done, you should again have a perfectly working iPhone.
If this doesn't solve your problem, you may need to restore using DFU (Direct Firmware Upgrade) mode. To enter this mode, plug in your iPhone and turn it off. Hold down the "Home" and "Sleep/Wake" buttons for about twelve seconds. You'll briefly see the silver Apple logo and then your phone will appear to turn back off. Release the "Sleep/Wake" button but continue to hold the "Home" button until you see a message in iTunes stating that it has detected an iPhone in recovery mode. Choose "Restore" and you should be fixed right up!
If this doesn't fix your problem, your iPhone may require a visit to the Genius Bar. You can find a local Apple Store and schedule an appointment at apple.com/retail.
Feb 25, 2010 | Apple iPhone (16 GB) Smartphone
Iphone dies and shows itunes picture
I fixed it. 1-uninstalled iTunes on the desktop. 2-turn off iTunes. 3- connect iPhone to USB wire to computer. 4- turn on iTunes. It detects it now. Then use restore. (damn it did not work) - 5- from number 2 onward repeated again. This tome it was restored.
Oct 10, 2009 | Apple iPhone Smartphone
Iphone 3g is frozen and touch screen wont work
If this unit is jailbroken you may want to do a full restore of the device, you will need to get the Iphone turned on and connect it to itunes, when you get into I tune and you phone is seen, right click on the device in itunes and tell it to restore.
This will reset the phone back to defaults, you will loose most of your data if not all.
If you can't get it to stay on or come on in Itunes then you may need to try this.
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
Aug 30, 2009 | Apple iPhone 3G
Iphone wont turn on
To fix this, you need to hook it up to your computer, run itunes, and let itunes recognize it. Itunes will notice it's not working right (you may need to play with it a bit to get to this point, otherwise just choose restore). When it's all connected, use iTunes to restore your phone to factory and try the jailbreaking all over again.
Good luck, let me know how that goes.
Caid.
Dec 29, 2008 | Apple iPhone Smartphone
Restoring iPhone
Hi. My 2G iphone was connected to Itunes and it was accidently disconnected...now the screen is showing a UBB cord with an arrow pointing towards the Itunes logo. can you help?
Oct 05, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
