Question about Maytag MER5770 Electric Kitchen Range
Maytag electric range shows F1 error message and beeps what does this mean? and now it permanently shows this message and not thee closk Over door will not unlock and range says F1.
  • Anonymous Mar 25, 2014
    door will not unlock following self cleaning and F1 shows on the pad
    Genius:
  • 3,422 Answers
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Posted on Jun 18, 2008
  • Priya darshan Jun 18, 2008
    http://www.maytag.com/assets/pdfs/litera...
    is the owner's manual. The F1 thing seems to be a common problem with
    this model involving the electronics - one or both circuit boards in
    the control panel. Most common solution: repair call and $$, although
    the Maytag repair people suggest resetting the oven by unplugging for
    about and hour and re-plugging the oven.
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: maytag electric range shows F1 error message and beeps
Posted on Apr 08, 2008
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
F1-4 Error message displayed
Hi jwill343,
The F1:-4 error code means "Runaway Clean Lower oven".`You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
(Positive feedback will be greatly appreciated.)
Mar 04, 2011 | Maytag MER6772 Gemini Electric Kitchen...
What is an F1-8 Error?
Hello there
First your f-1 error code
The F1 Error On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
And the 8 error is also conclusive along with the f-1 meaning that the erc or electronic range controle is faulty and should be replaced
Oct 12, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric range shows F1 error message and beeps every hour or so. we've checked the fuses and they seem okay.
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
Nov 12, 2009 | Maytag MER5770 Electric Kitchen Range
We have a beeping sound and an error message F1-8
The code F1-8 means you have a shorted keypad. Check to see if steam or other moisture is getting into the clock assembly. Replace the keypad if necessary.
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
Feb 13, 2009 | Whirlpool Washing Machines
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag MER5770AAW Oven
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Apr 03, 2008 | Maytag MER5770 Electric Kitchen Range
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
Maytag MER5770 Electric Kitchen Range Logo
314 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
