Question about Samsung SCX 4600 multifunction Laser Printer
Dont load the paper in tray and distributed paper.
When i give a command for printing the paper jam in the printer
Posted on May 13, 2011
3 Suggested Answers
komguy
  • 2306 Answers
SOURCE: I do not know where to put paper into the loading
You either open the flap in the back and stand the paper up in the slot or you pull out the drawer underneath the front and load paper in that cassette. You also have to select which one you are using with the feed switch.
Posted on Jan 08, 2010
MUKHTAR
  • 2017 Answers
SOURCE: Paper in tray won't load
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Posted on Feb 15, 2010
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Epson T60, Paper Loading Problem
Jumped through outside the tray? Plz, describe more clearly. Epson T60 is "best design" in paper feeder for A4 size printer. I have a lot.
Jan 23, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
HP Color Laserjet CP2025n Load Paper
In XP, go to settings; control panel; printers& faxes; then left click your printer and select "Properties". Click the "Device Settings" tab and you should be able to figure it out from there, by clicking the trays and selecting "not available". I have that same printer and I just did it with mine so I know it can be done.
Jun 08, 2012 | HP Laserjet Cp2025n Printer
I dont know where to put the papper in
I hope I can help!
Basically, you are going to load the paper in the very bottom tray. If you fold down the frontal tray, there should be enough space for a good stack of paper (but don't overload it!). You just put the paper in the bottom tray, and then it will feed through there and come out the tray just above it when it prints. If you need any more specific instructions, I will post a link to the HP manual on this printer. Just click on "load originals and paper" on the left, and then "load paper" and it has some good instructions with pictures. If you need any more help, just comment!
Link
I hope that helps!
Jun 17, 2011 | HP Deskjet F4180 All-in-One InkJet Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
My printer says load paper then press start, I have paper in there and it wont print.
Dont know what you have already tried but first off verify that you are loading paper to the correct tray. Now this tray is going to have a switch located toward the feeder that tells the printer paper is loaded make sure the paper is back far enough but not to the point where you are forcing the paper into the feeder. If all this still doesnt work try reseting the printer and printing a test page. Hope this helps.
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Document feed takes more than one page at a time
please follow these steps to solve your problem:
1.Fan the papers before loading them in printer tray.
2. Dont use papers that has lot of wrinkles
3. Dont insert your papers too long into your printer. Just load them with optimal distance.
4. After the papers were loaded, adjust the paper hold knob present on either side of the paper such that it holds the paper firmly on both sides.
Now your printer will take one paper at a time for printing.
I hope this is helpful to you. Please provide your rating and comments for the solution provided.
thanks
Mar 08, 2010 | Office Equipment & Supplies
I do not know where to put paper into the loading tray. dont know where the loading tray is... help!!
Jan 08, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Not reading paper
If you toggle the Feed Switch button (lower left side of control panel) to the Front Tray, does the printer print then? What type of paper is selected in your Printer Settings on the computer? I think that if you have selected anything but Plain Paper, the driver wants you to load the paper (photo paper, etc.) in the Rear Tray.
May 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Installation
There should be no "lock" on the tray.. I would assume you mean the second tray, you should be able to just pull it out...
Do you have the instructions??? they can be found here if you dont'. Check page 41 for loading trays...
Apr 05, 2008 | HP Color LaserJet 2600n Printer
Samsung SCX 4600 multifunction Laser Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
