Question about Acer Computers & Internet
My hard drive died. I just installed a new one. I have back up discs that I made when I first bought my acer laptop. I want to boot from cd but I can't seem to figure out how. I know how to get into the bios but I don't know what to change it to. All I have for cd-rom is one that says USB CD and that's not working when I put it to the top of the list. Any ideas as to what I can do?
    Problem Solver:
  • 12 Answers
The backup disc's May not be bootable discs meaning that you cant start up with them. You should see if you can find recovery discs that came with the laptop, this should be able to get your OS back and running, then once your up run the back up disc's in windows and you should be able to restore the data.
Posted on Jun 18, 2008
Took acer 6733Z-4633 to tech. it wouldn't boot up. he said hard drive bad. he was able to save pictures and some files to USB. now I need to replace hard drive. sent for Acer recovery discs. if I cant...
when your laptop starts if it has F12 option push that and install your first disc and choose boot from cd player then follow instructions
if you dont have the F12 option when you puch the power button toggle the F2 key and go to boot menu and choose the cd player as first boot option and then hit F10 and save install boot disc and follow instructions
Aug 18, 2013 | Acer Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
My acer aspire 5920 is in chinese and i need to know how to change to english
use your XP install disc (or Vista or whatever OS you use) to boot up your laptop and do a Repair Install. Usually you will get a prompt to "Boot from CD by pressing any key." during the power up of your laptop. If you dont get that option, reboot and go into BIOS and change your boot order ie have the CD drive as first boot option followed by your hard drive. Then try booting again with your XP disc in the cd drive.
You can change the language to English during a Repair installation but you may have to re-enter your serial number and activate again on-line again.
Cheers,
Steve
Aug 21, 2010 | Acer Aspire 5920-6727 Notebook
I bought a new hard drive for my acer 5100 and it
The different model of hard drive should not make a difference. As long as you are using the same type....IDE or SATA...you should be fine.
If you installed the new drive and now the computer keeps rebooting....you probably need to tell the computer to boot from the CD first and not the Hard Drive. When you first turn on the laptop, boot into BIOS by hitting the DELETE or F2 key....it is normally the Delete key.
This will boot into BIOS where you can find the BOOT OPTION menu and select the CD as the first boot device. This will allow the computer to boot from the Windows CD you should already have in your cd drive.
If this does not help.... I would take the new hard drive out and boot the computer without any drive installed. If you are still in a reboot loop, the problem is not with the hard drive and more than likely an issue with the RAM. To rule out the RAM, take one stick out and see if that makes a difference...repeat with the second stick....
Hope this helps
Jun 04, 2010 | Acer Aspire 5100 Notebook
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Toshiba Tecra Notebook
INstall the hard drive, if the hard drive came with a cd, put the cd in the drive and boot the laptop. When you see it say "boot from cd hit any key" do so and follow the prompts. This software will "initialize" the disc and install for the first time. Once the disc is "officially" installed take the hard drive disc out of the drive and replace it with Operating Disc. Reboot the machine and again look for the "Boot from CD Hit any Key" hit any key and let the system load windows. You only have to hit the key one time when it says "hit any key" even if during the windows install, the system may reboot but it still may need the disc in the drive, if you see the heading "boot from cd hit any key" dont hit any key any more....just let windows finish loading. When windows finally reboots, sometimes up to three times, then you can take the disc out of the drive or take it out if the operating system instructs you to. Good luck, ParrotHead PC Repair
Sep 04, 2009 | Toshiba Tecra 500CDT Notebook
How do i replace a hard drive in acer 2303lc-
Hi there
Put the cd in the drive, restart the PC and hit F2 while it starts, go to the boot options and choose the cd drive as first boot device, hit F10, save and exit, the pc will restart and then will boot from the cd, it may ask you to press any key to boot from cd, you will then see setup screen and the new operating system will start to install.
Good luck and thanks for using Fixya!!
Feb 15, 2009 | Acer TravelMate 2300 Notebook
System Restore
Recovery procedure for Acer netbooks.
Important Information
The Recovery disc will help you to restore the hard drive with the original software content that was installed when you purchased your notebook. Follow the steps below to rebuild your hard drive. Your drive will be reformatted and all data will be erased. It is important to back up all data files before you use this option.
Restoration procedure:
1. Press the power button to turn the system on.
2. Select to boot from a USB optical drive. There are two ways to do this:
2.1. Press <F2> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup) to enter BIOS Setup.
2.1.1. Select the Boot menu.
2.1.2. Refer to onscreen instructions to set the first device to any bootable optical disc drive.
2.2. Press <F12> during the Power-On Self-Test (when the Acer logo is displayed onscreen after bootup), and select the USB ODD from the list that appears.
3. Ensure the Recovery disc is in an external (USB) optical disc drive, and exit the boot selection menu, by selecting Exit Saving Changes from the Exit menu or pressing <F10>, or by pressing <Enter> as appropriate.
4. Select Exit Saving Changes from the Exit menu or press <F10>.
5. Follow the onscreen instructions to complete the installation process.
6. When you finish the recovery process, please remove the Recovery disc and insert the System disc again.
7. Restart your computer.
Jan 25, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
