Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a 2001 GE Profile Model JE1860SB001. If turned on sparks come out a vent on the right side wall and a silver carboard cover caught on fire (self-extinguished quickly). What could be the problem? Worth repairing?
reg501
  • 413 Answers
SOURCE: microwave ovens
The Magnetron has failed, causing the waveguide to become damaged. If the waveguide is damaged/burned the microwave can not be repaired and should be replaced.
Posted on Dec 25, 2008
  • 1462 Answers
SOURCE: GE MICROWAVE OVEN W/CONVECTION AND
cover is made of mica and is not flammable. you can obtain sheet of mica from a good spares stockist, cut out a new cover and fit
Posted on Sep 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 16, 2008
danforddan1
  • 192 Answers
SOURCE: GE Profile spacemaker stopped heating
You may have a fuse that burned out. not everything runs on the same circuit . If its not the fuse than its probably the mega-tron, and that's big money. Check the fuse first. good luck DFD
Posted on Apr 22, 2009
woobie dog
  • 1273 Answers
SOURCE: microwave exploded
That bugs me to no end. Call GE back, and ask for that person's manager. If they give you no joy, ask for the next person in the chain of command, until you get it replaced. Microwaves don't just explode. They should make it right. Most larger companies like GE have a consumer advocate. Ask for one of these. They can "cut out the middlemen" and get action on this issue.
Go get 'em! --W/D--
Posted on Aug 13, 2009
I get an occasional spark when microwave is in use
Presuming that you have iliminated the possibility of any metal objects that are not meant to be in the machine being in there (and this includes dishes and other items with silver or gold leaf on them, which WILL spark and burn!) then take a look inside the oven its self. You will find a waveguide cover. It is usually a strange flakey silvery plastic/card like material called Mica and is usually on the same side of the microwave wall as the control panel (So if the picture on this thread is accurate, I will guess the Mica cover is on the right hand wall inside as you look at the machine from the front) . Over time, the magnatron (the thing that creates the microwave energy) will often burn a hole through the mika, or cause a dark brown or black burn mark in it. If this cover is even slightly damaged then it may well cause sparking inside the machine. These covers are designed to be removed and you can buy replacements for them from electrical stores.
Aug 12, 2011 | GE Advantium SCA1001HSS Convection...
I have a GE Profile convection/microwave oven, Model No JVM1790 BKC01. One of the plastic clips that holds the oven rack in place caught fire. Location of clip is top front right hand corner next to the...
Most rack support problems I have seen are from food splatter or grease getting around the support and even seeping behind it. Once it starts burining it must be replaced. It is really important to keep the area around them clean and dry and free from food splatter. A Microwave cannot tell what is on a plate or on the wall or rack support, and every food particle cooks each time the unit is run, until it turns to a carbon deposit and starts to attract the microwave energy and starts to ARC to that point.
Then it burns up the part it is arcing to. Have to replace support and scrub the area and inside of the cavity perfectly clean.
Oct 25, 2017 | GE JVM1790 Convection / Microwave Oven
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
I have a GE Profile Model #JE1860SB001 serial #MV903523K. In error I set the cook time to 60 minutes (thought I was setting timer to 60 min.) & it overheated - melted an empty polyethylene cup which...
The magnetron may or may not have been destroyed, but at the very least the thermostat on the magnetron probably was.
Its job is to interrupt power when the mag gets too hot, in order to stop the heating process with the aim of saving the magnetron.
There is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Dec 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
BAked Potato caught on fire in GE Microwave
Fuse is behind the control panel. Has cavity sensors and a magnatron thermal disc also. Start with the fuse and then pull it down if not the problem. Eric
Aug 27, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Microwave exploded
Go get 'em! --W/D--
Aug 13, 2009 | GE Microwave Ovens
My mothers Kenmore countertop microwave oven caught on fire late one evening. She remembers nothing of the fire circumstances as she was in a burn center for six weeks. My sister had the same model...
There is a GE/Kenmore recall: http://injurylaw.reganfirm.com/2007/12/articles/defective-products/cpsc-notice-ge-ge-profile-kenmore-microwave-ovens-recalled/. I don't know if your relative's models are involved. I suggest that you file an incident report with the Consumer Product Safety Commission.
Aug 03, 2009 | Kenmore Microwave Ovens
Sparks ae flying in my microwave
GE in essence says it is unrepareable and insafe. I suggest that would be saying it is trash.I don't know what that carboard is, possibly indulation? Ot may have /be a a oiece oce of laminated metal like some paper plates have..Not replaceable is a poor answer. Call them back and make a fuss. If it's not too far over warranty, they may work with you to shut you up.. oops, sorry, to pacify you.
:-) Good luck.
May 28, 2009 | General Electric Microwave Oven
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Jul 25, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
375 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
