Question about Refrigerators
I have a Daewoo frost free combination fridge freezer with water dispenser- I don't know the model number but it must be 6-7 years old. In the summer the motor seems to run continuously and then freezer temperature never gets down to freezing (its OK in the rest of the year). Is this a sign of gas leak? Now a more urgent problem has occured in that when the thermostat cuts in and the motor starts up there is a loud screaching noise coming from the LH side wall as if a fan motor bearing is running dry or a fan blade is slipping on the motor shaft, after a few minutes the noise stops. How do I get to this motor? I thank you for your help in advance Peter Roberts.
  • Peter Roberts Nov 16, 2010
    The comments received were non specific for my model and could apply to many other fridge problems.I stated that my unit was frost free and that one of the air circulation motors or fans was intermittently faulty. Finally I live in Spain so I don't think Sears will want to send me a repair engineer. No further help required as Daewoo have a repair dept 20 km away.
  • Peter Roberts Nov 18, 2010
    Thanks for your suggestions. The model is NOT side by side and the identification plate is at the back (FR581NW). Noise was due to evaporator fan bearings becoming dry but compressor unit has been diagnosed as faulty and has to be replaced. I will scrap the unit and buy new one as there are other problems due to its age. NO MORE suggestions required please.
  • 441 Answers
As far as the poor cooling in the summer months goes it sounds Your door gaskets dried out and this keeps it from getting a good seal, to fix this just apply a thin layer of vasoline to the door gasket, this will let it expand and give you a good seal. The sceaching noise is a bigger issue, you are right in thinking a bearing, should be the defrost fan motor that is giving you the sound, to view a parts breakdown on this you will need to find the model #, then go to marcone.com to view a breakdown of the ref and order the new part
Posted on Nov 19, 2010
    President:
  • 1,796 Answers
Hi!!
In order to better assist you I would need the units model No. I am assuming that your unit is a side by side, so here is a diagram on where to look for the model number.
In the mean time, the problem with the unit running all the time could be related to the evaporator fan OR to a faulty evaporator fan or dirty evaporator coil. Unplug unit from wall outlet and use a vacuum with the small brush attachment to clean the back of the fridge, be gentle on the coils, they bent easily. This is part of the units maintenance. While you're there, check that the condenser fan is working. It should kick in strong when you plug unit back on the wall, if you notice a drag or turns slow, replace it. If notice problem to start but when it does is fine, replace starting capacitor.
Good luck!! keep me posted!
Posted on Nov 17, 2010
  • Refrigerators Master
  • 3,083 Answers
The first problem you're having could be caused by a few things- low refrigerant, dirty compressor coils (usually underneath), or a faulty defrost circuit (leading to ice on the evaporator coils),
You have to have a certified repair person to check, and refill the refrigerant. I think that's one of the possibilities here, since the unit sounds like it's struggling all the time to get the temperature down.
The second problem is most likely a bad fan, or compressor. You will have to determine the model number (they can be inside the unit, or on the back of it), and order a replacement, if it's the fan, or call a repairman if it's the compressor. Here's a site that offers parts for this make:
http://www.espares.co.uk/parts?k=daewoo+fan
I'm not a HVAC certified person, and have some work on refrigerators, and there's always a way to get to the replaceable parts, although it's often not apparant, or easy to the "first timer" guy.
If you go to the following website, and enter your model number, you stand a good chance of getting diagrams and parts lists for your unit, and they will show you a blown up assembly diagram, which should help you figure this out. Here's their site:
http://www.appliancepartspros.com/
Otherwise, call a local Sear's or other appliance repair shop and see if they can tell you something helpful. I noticed Sear's has sold some Daewoo products, so they may service them also.
I couldn't find any site for Daewoo on the net, and the only link that came up was discontinued, so I'm not certain if they're still in business- Sear's may have some number or way of contacting them if you need to.
I'm thinking, since your compressor has been working overtime, it may need replacement. Get a repairman to check it out, after you clean it, if that doesn't help.
Good luck, and I hope this helps.
Posted on Nov 13, 2010
Doewoo no frost fridge freezer is working fine except that we keep getting puddles of water under the freezer door. any ideas. had about 4 years now
probably a blocked drain outlet or pipe. At the bottom rear of the unit, mine had a drain pipe blocked with a plug of mould (5/6 years old machine), apparently quite common. I detached the pipe and cleaned it out and replaced it.
From inside the freezer, I removed the lower back panel and thawed the ice build up on the drainage tray below the defrost heating element, leading to the pipe outside. The puddles of water that was appearing every defrost cycle have now stopped - permanently I hope. Hope this helps you
Sep 02, 2012 | Daewoo Refrigerators
Maytag fridge model# MSD2561HES
Look inside the freezer for frost buildup on the rear wall. Let me know if there is frost building because that would indicate a defrost problem causing the warm up. Also check your model number because you are the only one on the internet with a model MSD2561HES for the USA Once you have the correct number and answer back about the frost buildup I will tell you each step to take solving this problem which I think is a defrost problem at this point, Thanks Sea Breeze I think your model has the adaptive defrost control board that may be at fault=> 4388932 Defrost Control Board
Aug 19, 2012 | Maytag 25.6 cu. ft. Side-By-Side...
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Model FRS-U201A fridge freezer and fridge is not keeping cool, only 3 years old, ssems to have occured in a couple of days
look on back wall of freezer if there is frost build up you have a defrost problem can be defrost heater defrost control board or bi-metal is open and not tuning heater on if no frost you may have low freon problem this can cost check first part of this post 90 % of the time its a defrost issue
Aug 18, 2011 | Daewoo FRSU20IA Freezer
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 | Freezers
Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
Feb 11, 2008 | Freezers
Refrigerators Logo
193 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
