Question about Kohler Home
My ingenium flushing system continues to run for a minute after it fills. During this minute the water overflows into the tube in the center of the tank.
  • 10,515 Answers
Most of the time with your symptons it is either the flapper chain is too loose or you have the wrong flapper installed.
Kohler tanks take a special flapper and the generic flappers will work but not as well as the Kohler flapper designed for that tank.
The lift chain should not be tight but just slightly loose. If it is too loose, the handle travel is near the end of its' lift range before it lifts the flapper and the flapper is not lifted high enough to float long enough for enough water for a full flush to pass before it falls back on the valve seat. Wow, that was a mouthfull. Conversely if you get it too tight and the chain kinks a little the flapper may not completly seat and allow water to leak by.
The overflow tube is primarily a safety device. If the ballcock does not shut off completly the overflow tube merely allows the water to run through the bowl instead of overflowing the tank.
Depending on the model of the water-closet there could be other issues but it sounds like a simple flapper thing. Adjustment or the wrong flapper. When you get a bad flush the flapper is closing before enough water has been allowed to pass. You can always hold the handle for a few seconds and accomplish the same thing.
As far as the back-up is concerned I don't think that should be an issue but the water should not back up in the tube unless there is a restriction somewhere in the bowl waterways. I have seen many things get lodged in water-closets and it is always a possibility.
First make sure you have the right flapper and it is properly adjusted.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 14, 2010
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Feb 16, 2013 | Kohler Toilet - One Piece with Ingenium...
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
Should water be coming out of the base of the vertical float tube just inside of tank or only by the flexible fill hose connected to top of float? this is a koehler ingenium system. my tank is constantly...
yes both, but you have a float adjustment issue
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Kohler Toilet - One Piece with Ingenium...
Toilet keeps running even when manually lifting floater to max
check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Oct 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Replaced the flapper with a new one and the toilet will lose water until it triggers the fill valve in maybe an hour. Is the gasket betwenn the tank and the cistern leaking slowly?
check the fill tube. sometimes they crack, put some food coloring in the tank and that will help you find leaks too. gently squeeze the tube and see if you see water running down the inside of the tube
Aug 02, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
How do you get the top plastic cap off the Kohler Ingenium flush
My Kohler Ingenium has no pins. The white cap is attached to the grey lever which must be lifted up before twisting both one-eighth turn counter-clockwise, and lifting off of fill tube. Turn the water supply back on and flush the tube out (cover with cup first!). Use a thin wire rod about 12" long to gently poke down into fill tube to clear any clogs. Also check where the small flexible fill tube exits from the main fill tube. Reassemble and cross your fingers.
Mar 26, 2009 | Kohler Toilet - One Piece with Ingenium...
Home Logo
146 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
