Question about Rheem Water Heaters
I have a RuuD Power vent 50 gal.gas water heater (pvp50-1) with power glow ignitor. it is not providing hot water. the ignitor is functioning and the fan is running continous however there is no lighting of the burner at the bottom of the tank????
3 Suggested Answers
SOURCE: Rheem water heater with powerglow ignition wont re-light
I have fixed mine. The problem part is the Ignition Control module. It is made by Robert Shaw part # SP10758. I paid $93 plus shipping.
Works great now. A repairman wanted to sell me a gas valve for $488.
Watch out for these people.....
Posted on Jan 10, 2009
heatman101
  • 43501 Answers
SOURCE: our rudd water heater model #PVP50-1 (50gal)
The ignitor has gone bad... you will need to find a replacement ignitor and change it..they are not had to change but are very fragile to handle.
That will get you working again...
heatman101
Posted on Mar 27, 2010
Testimonial: "very helpful, i was hoping we didnt have to buy another one though."
I have a 20 year old Ruud gas water heater with a power vent. The model is PVP 40-1. Sometimes it will not heat water. The power vent is running but neither the ignitor or the burner is. If I turn off the...
My guess is the ignitor needs replacing (old and has built up too much internal resistance). Even though it still works at times, I would suspect it first, even if it glows during an ignition cycle.
Dec 07, 2014 | Water Water Heaters
I have a power flex 50 gal power vent model number pvg625ot6onv.. Serial number, 0932t413742. I got a new lighting element, and installed just fine but the actual ignitor keeps dropping to vacation...
Sorry to hear about your wife.
Please copy following links for Intellivent troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.americanwaterheater.com/
Clean air intake located on bottom of heater using compressed air or feather duster. Use auto inspection mirror and flashlight to see under the unit.
Age of water heater appear on label on side of tank.
Look for serial number.
Powerflex is American water heater product (AO Smith)
First 2 digits of serial number is year of manufacturer, digits 3-4 are week during year.
Nov 26, 2012 | Water Heaters
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
The water heater will cycle 5-6-7 times with no probles then it fails ignition. The water heater is a rheem 50 gal power vent 2. It is about 2 years old.
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
Apr 13, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Mar 16, 2009 | Water Heaters
Power vent blower
Check the amp draw on the motor, If its above the draw specified on the data sticker on the motor itself, then the windings are going bad causing the reset to pop.
If not, then the switch itself is going bad.
Dec 30, 2008 | Water Heaters
Water Heaters Logo
299 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
