Question about Husqvarna Garden
THE CHAIN SLIPPED OFF HOW DO YOU GET IT BACK ON 14 IN HUSQVARNA
    New Friend:
There's two 1/2 inch nuts on the side of the cover from which the bar protrudes.
Remove these nuts and the cover -- leave the bar loosely in place.
Look for a slot-head chain-tensioning screw (may be on front under the bar, or perhaps on the side).
Turn this tensioning screw counter clockwise -- you will notice a pin moving back towards the drive clutch -- this pin fits into a hole on the bar and is used to set the chain tension by pushing the bar away from the drive clutch.
Once it is loosened, the bar can be pulled closer to the drive clutch, allowing you to fit the chain back onto the bar -- be careful to align the drive teeth on the chain into the slots on the drive clutch.
When the chain is back in place, turn the tensioning screw clockwise to tighten the chain onto the bar.
Replace the cover and put the nuts back on only finger-tight.
Tighten the chain some more using the tensioning screw.
Tighten the 1/2 inch nuts fully.
Note: The chain needs to be quite tight -- lift it by a link and be sure it does not come out all the way from the bar.
Posted on Nov 13, 2010
SOURCE:
How to remove top cover
Also, if it has a brake, make sure the brake is not pushed forward. This will cause it to lock on and not release the cover
May 15, 2014 | Husqvarna Chain Saw Chain 14"
Can you recommend a replacement 14in. bar & chain that will fit a Husqvarna 61 chainsaw
There is a genuine Husqvarna 15" bar available for the 61, part no 508913156, chain part no 501841456
Jul 15, 2012 | Husqvarna Garden
What's the biggest bar i can put on a husqvarna 240?
The 240 origanaly had a .325 pitch chain and ran a 15" bar, it is not avisable to go any longer as the power loss will be great, the later machine had a 3/8 chain and ran a 14" bar, the loading on this smaller chain chain would allow you to fit the 16" bar, i think this will be the longest bar you can fit due to power and chain oil pump capacity
Jul 13, 2012 | Garden
I have a 14" Poulan
Take off nut, remove bar and chain, turn adjusting screw counter clockwise, replace bar and chain tighten screw, replace nut.
Aug 31, 2011 | Poulan 14" Chainsaw
I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain will not stay on
Hi Dave:
If you hold the bar nose up when adjusting and tightening the bar, then I think your saw is like detail A here (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2008/HIUS2008_506955901.pdf
Configure it like detail B and the problem is solved. I did a quick search for item 16 (<$25) and available. You also need item 14 (2 each, $1±), and a scrench ($10± at a local saw store after you get the bar nuts).
If the saw listed is not yours, you can find yours here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How interchangeable are replacement chain bars for older Husqvarna chainsaws? I've never replaced one before and was considering buying one from Sherril on-line which is on sale, a 14 inch Husqvarna Intenz...
Your question can't be answered as aked.
If your saw requires an Intenz 14" Bar it's Oregon pns 140SDET041 or 140GPET041. Part number 140SDEA041 if not Intenz.
Plug in your requirements here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Once you get a part number it can easily be converted to other manufacturers numbers. HTH
Lou
Nov 03, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My chain came off. How do I get it back on?
Use page 25 of this downloadable manual as a guide.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=359&types=O
Loosen your tension adjust before attempting to fit the chain on the bar.
HTH
Lou
Sep 25, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
