Question about Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa
How to remove the back cover to change the code on the lock
  • 963 Answers
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 06, 2011
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
I am trying to open access cover from power board to change batteries and change code. But access cover won't comeout . There are no screws, and pulling isnt helping. Please help. I have the manual but of...
Here is a link to the Frequently Asked Questions page, which illustrates how to remove the cover:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Feb 05, 2011 | Weiser Lock Powerbolt 1000 Lock
We lost the directions how do you change the code and how to get the back off
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
Dec 01, 2010 | Weiser Lock GED1460X3BR Lifetime Polished...
How do i change the belt on a model No. DE308 maytag dryer
Hi
To change the belt you'll need to remove the top paenl and then remove the drum and you would be able to see the belt. You can disassemble it by the following procedure--
Drum Removal / Roller / Glide Access--
  • Disconnect power supply to unit.
  • Remove Top Cover and Front Panel,
Top Cover / Door Switch / Front Panel /Gasket Removal-
1. Disconnect power supply to unit.
2. Use a plastic putty knife to depress the locking clip between the Top Cover and Front Panel.
3. Disconnect wiring from the Door Switch.
4. Depress the locking tabs on switch side and remove through the front.
5. Remove two screws, 1 each side, from the back flange of the Front Panel.
6. Tip Front Panel back and remove. Rotate Front Panel to the back side and remove gasket.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Dryers
Battery cover wont come off
Jan 13, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Lost manual and need to change the code what are the steps
Jan 05, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do i change the code in my kwikset 909 keyless entry
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Jan 07, 2009 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do you change a cabin air filter for s500 mercedes
remove the glovebox assembly-usually 4-6 philips screws in glovebox,remove and pull out glovebox,there is a plastic cover with a white lock slide at the right side of the heater box-light it up and remove from tabs,remove filters and install plastic tabs up,when installing the cover back on with white locking tab,make sure you get the tabs back into their slots and lock down-might cause whistling if not properly installed,reassemble
Jul 31, 2008 | 2007 Mercedes-Benz S-Class
Weiser Lock GED1460X3BR Lifetime Polished Brass PowerBolt Powerbolt Touchpa Logo
55 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
