Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven does not work E1-F1- code help
We have had lots of problems, all that are listed here and this one. E1-F1- no oven. Two thanksgivings lots of guests, no turkey!!!
  • jasbike Jun 18, 2008
    I hope all have fun cooking as I do. I love the timer on timer off function, which does work.
  • Anonymous Jul 10, 2008
    F1 error
Go to the following link any you will find a possible solution for your problem.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have now shared my fix with over 1800 folks and most report success. If it works for you please let me know at:
hutchipop@yahoo.com
Good Luck,
Powerman
Posted on Jun 19, 2008
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
The oven does not work it says turn off when i turn it on and flashes F1 and E1 codes
The E1-F1 error code means per the service manual "safety flip flop" what that means that a internal component of the control board has failed and thusly the control board would need to be replaced
GENE
Oct 25, 2011 | Ovens
What does the error code F1 E1 mean and how can i fix it
Hi.
F1 - E1 means: EEPROM Checksum error. The EEPROM is a memory chip located in the ERC (control module). The problem is communication error with the EEPROM
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-Ex codes except F1-E3.
Regards.
Ginko
Aug 29, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
What does error code F1 E1 mean on a kitchenaid built in oven?
F1 - E1
1.
Note: Applies to all F1-E...
codes except F1-E3.
Feb 14, 2011 | KitchenAid KEMC378 Electric Double Oven
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
After a power outage oven will no longer work
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven has error E1 F1 will not work
F1 - E1
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
Kenmore oven/range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
276 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
