Question about Lexmark X2650 All-In-One InkJet Printer
Lexmark X2650 3-In-One Printer/Scanner - no power! - It has lost power totally. I wasn't using it for a while, so i had disconnected it and packed it back in it's original box for a few months. Reconnected it the other day, and there is no power at all! I don't know why. I checked the fuse by switching it with another working one, to no avail. I'm totally mystified!?! I am usually ok with power leads, joining, repairing etc usually, but these days they're all sealed in, so am not sure its a good idea to go trying out different power leads! Maybe this happened to someone else who has resolved the issue and please could now help or advise me? Am worried that, like alot of major brands, this is bound to be something designed to be dealt with in the most expensive way, as usual! Thank you in advance for any advice :-) Chrissie
    Habit-Forming:
    New Friend:
  • 29 Answers
Your problem may be ur power adapter has gone out... try replace by checking your input volts and ampere as well as output volts and ampere. you can use compatible also. if same problem occurs it might be the power supply area problem inside the printer
Posted on Mar 15, 2017
SOURCE: Lexmark X 1270 Can not Print
try reinstalling the driver
Posted on Dec 20, 2007
Ajkill
  • 2035 Answers
SOURCE: Paper Jam issue
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 25, 2008
  • 11 Answers
SOURCE: Error: Release the scanner lock switch:
The scanner lock is locked pls unlock it dude...
Posted on Apr 28, 2008
ashleyjaicee
  • 33 Answers
SOURCE: Lexmark x85 all-in-one inkjet printer not working with vista
hi jjzee,
it seems that there is no available driver that you can used for windows vista.
if you want, you can try to download the driver in this link http://driverscollection.com/?H=X85&By=Lexmark and hopefully you would be able to install it.
but if still there's no luck, better call lexmark and ask if they have driver for your printer that will work with windows vista.
have a great day ahead.
Posted on Oct 02, 2008
SOURCE: I recently purchased a Lexmark
cna not remember how to scan and print
Posted on Jan 06, 2009
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
Lost cd to install lexmark2500seriea
Please follow the link below to get the driver for your printer
http://www.drivershq.com/Drivers/VistaDevices/Lexmark-2500-series-scanner-driver/7990/Drivers.aspx
Please rate accordingly
Thank you
Computerrep
Mar 28, 2008 | Lexmark X2550 All-In-One Printer
Lexmark X2650 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
