Question about Sanyo VPCS885 Digital Camera
Good am....my daughter dropped her camera. it will now no longer turn on or off and it's stuck with the shudder open
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 14, 2010
Shutter button does not work after camera was dropped.
You dropped it and that is the problem, it is junk. Repair cost will exceed price of good camera.
Oct 11, 2012 | Kodak Easyshare C1530 14 Mp Digital Camera...
My Samsung BL103 was dropped by my daughter and now the camera won't turn on and the lens is stuck in the out position.
There is Lens adjustment out you need to fix this problem by opening your set and Lens block to readjust.after that it will work.care fully handel this.
Oct 30, 2010 | Samsung BL103 Digital Camera
My daughter dropped our A520. The power comes on for a second and then shuts down. The lens is stuck open. Is this worth fixing?
I had this problem once. The lens was stuck open and the power would not go on. I took out the storage card and the lens retracted.
Aug 23, 2010 | Canon PowerShot A520 Digital Camera
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Dropped sony camera randomly turns on batery is
The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either condition causes the camera to shut down to prevent further damage. There is no safe DIY fix, but the camera can be professionally repaired. Contact Sony through their web site or visit a local camera shop (not the department store) and get a repair estimate -- you will need to decide if the camera is worth the cost of the repair.
Nov 14, 2009 | Sony Cameras
I have a Cannon SD1000 stuck in revie mode. My daughter pulled it
If this was indeed dropped STOP! take it to a camera shop so they can do the repairs as you could damage other parts in the camera.
What could have happend when she dropped the camera the sensor inside got stuck into position to protect it from further damage. My advice is spend a couple bucks and take it in you be glad you did!
Sep 17, 2009 | Canon PowerShot SD1000 Digital Camera
Lens Stuck open and wont turn on
My daughters Sony Cyber-Shot had the same trouble and I read that many times it is caused by foreign matter getting in the lens gearing. 1st suggestion was to hold the camera firmly in one hand and hit one side into the palm of your other hand. Do the same with the bottom, other side and top. Also spray a jet of air into where the concentric lens parts rotate when it opens. Use some judgment, do not hit on a hard surface or spray directly into the glass lens itself, or try to force any movement.
By combining these actions repeatedly I was able to get the camera to first open up and then zoom properly, just as other Sony customers had, Yea ! I then remembered that she was at the beach the day before so when I gave it back to her I guessed that she dropped it in the sand. She had of course.
Good luck, it worked for me
Jmatt
PS Make sure battery is charged :).
Nov 24, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
The lens is out
I have the same problem. Camera was dropped and now the lens is stuck and when I turn it on, just tells me to turn of the camera off and then on again. But still stuck. It won't take pictures.
Jan 14, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck open
Hi! Sounds like we have the same problem but mine says lens error 221,0,0,0 and my daughter dropped mine. If i dont get an answer soon, im sending my in for repair, it will only cost me $50.00. Here is the website incase you want to fix yours :) WWW.Kodak.com and just click on the repairs and services. Good Luck!!
Jun 18, 2007 | Kodak EasyShare C703 Digital Camera
Sanyo VPCS885 Digital Camera Logo
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
