Question about Konica Minolta Magicolor 1600W Printer
HI, After changing toner YMC on Konica 1690MF, Printer starts up but goes to error and will not clear. : PROCESS ERROR BELT clear by cover i don't understand that it want ? thanks Guy
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
Posted on May 11, 2010
  • 518 Answers
SOURCE: the screen says YM toner low. Does this mean
the lazer unit needs recharging
Posted on Jul 06, 2010
SOURCE: My Konica Minolta magicolor 1690MF makes a
Greetings,
I had the same trouble with my 1690 and called Minolta tech support.
Their explanation to me was that if I used re-filled cartridges, instead of Konica-Minolta originals, that I would have the noise problem.
Posted on Aug 04, 2010
SOURCE: I have konica minolta magicolor
Remove the Yellow toner Cartridge see if the printer will print without the cartridge, you can cancel the warning and there should be an option to check or uncheck saying do not show this warning again/in the future.
Posted on Sep 06, 2011
nonontech
  • 4737 Answers
SOURCE: I have no driver and can't load a driver for My
Open this LINK, scroll down the page to the section called "Mac OSX 10.6.X - Drivers" and download your drivers. Hope this helps. Good Luck.
Thanks for using FixYa.
Posted on Sep 21, 2011
Ow do i fix the error message MACHINE TROUBLE SERVICE CALL (0310) on my konica...
replace the print head. That's the part that houses the LASER. try this site for the part
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
if not try local Konica Minolta dealer
Sep 28, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Error belt cover erase process
that is what is displayed on the control panel?
Feb 11, 2014 | Konica Minolta magicolor 1690MF All-In-One...
How can I correct this: process error-belt clear by cover,i need help????? on my Konica/Minolta 1690mf
I think this is mechanical problem and you need to check and remove belt-related assembly part.
Thanks
Sep 20, 2013 | Konica Minolta magicolor 1690MF All-In-One...
0092 error
CAUSE: The transfer belt is not rotating correctly inside of the Image Unit.
SOLUTION: Check the PRCB connector for proper connection and correct as necessary. Also, check Belt Positioning Sensor (PS6). Replace Image Unit (p/n A0VU011). The PRCB may also need to be replaced. (p/n A034 H001 06 for magicolor 1650EN or p/n A034 H009 07 for magicolor 1680MF/1690MF)
SPECIAL NOTE: Solution contribution by SSD Printer Support
ID No.
TABP1000085EN
FROM KMBS SSD
Jun 20, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Change ymck toner
The toner cartridge has a chip that calculates the estimated usage of the toner and once it reaches it's capacity (per estimation), it will not print. The only thing you can do is to buy a new cartridge or buy refill toner that comes with a reset chip.
Aug 30, 2012 | Konica Minolta magicolor 1690MF All-In-One...
I have a konica minolta 1690mf. paper feed problem error 094
Transfer roller issue. the sponge looking roller across from the transfer belt.
Jun 26, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta 1690mf process error belt clear by cover
KONICA MINOLTA 1690MF ERROR:
process error - belt (clear by cover)
SOLUTION: Open and close the scanner unit. Reseat the Image Unit and cycle the power to the machine. If the error persists and the machine is covered by warranty, a printer exchange is recommended.
KONICA MINOLTA SUPPORT PAGE:
https://kb.mykonicaminolta.com/selfservice_bus_anon/microsites/search.do?cmd=displayKC&docType=kc&externalId=TAD-doctad227704html0&sliceId=&docTypeID=DT_TAD_1_1&dialogID=10562139&stateId=1%200%2010556672
Feb 27, 2012 | Konica Minolta magicolor 1690MF All-In-One...
Konica Minolta Magicolor 1600W Printer Logo
438 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
