Question about JVC GR-SXM37U SVHS-C Video Camcorder with a 2.5 LCD Screen, 25x Optical / 1000x Digital Zoom
My cam. goes into e03 safegaurd mode please remove bat. and rehookup.when i do it plays again for about 5sec. and does it again
    Guru:
  • 2,178 Answers
The mechanical section which consists of the tape cartridge and VHS-C tape plain has a timing misalignment. Check the inside for possible obstructions of the tape guides not fully sending the tape to the heads - sometimes it gets stuck. It will likely need to be taken apart to resolve the issue.
Posted on Nov 13, 2010
My Moultrie I40 seems to be stuck in set up mode. won't advance to Auto. test button brings back error 4800. Tried calling their customer service, no matter what extension i select i just get hung up on.
what does battery % say? twice this prob was solved by using good brand new bats; might try removing bats with cam on; turn cam off; replace bats and power up. Wait until setup screen is on before pressing mode.
Aug 09, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Error 3
An error of 03 or 04 indicates that the unit is in safegaurd mode.
Elect the cassette once then re insert it. If the error is still visible you must contact your nearest dealer.
Here is a link to the user manual and troubleshooting guide.
http://uk.jvc-service.net/webtemp/GR-D250EK.pdf?CFID=1168480&CFTOKEN=98803594
Regards
Marc
Apr 16, 2009 | JVC GR-D250 Mini DV Digital Camcorder
E03 safegaurd mode remove and replace battery? how can you fix problem? I have removed battery several times and get the same error code. (RCA CC9370 digital camcorder.)
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
Mar 28, 2009 | RCA CC9370 Mini DV Digital Camcorder
DVL315 Did get hot NOW Error E03 Showing up
Take the battery out and leave it somewhere cool (not cold - over 10 degrees C) for 24 hours - this may help.
Jun 13, 2017 | JVC GR-DVL315 Mini DV Digital Camcorder
JVC GR-DX67EK MINI DIGITAL VIDEO CAMERA
Previously, when I have experienced this problem, I have removed the battery for 24 hrs and on replacement switched the Camcorder to (M) and quickly pressed the "Menu" button. This has allowed me to scroll down the menu options to the Cam Reset option. Then I reset the camera and all is well. This has worked for the last 3 to 4 occasions, however, this time I cannot get the menu to stay on long enough to reset the camera. Any ideas?
Dec 10, 2007 | Video Cameras
Error E03 -
I tried Tapping on side of Camcorder and I worked, after 2 or three times while message appeared.
Oct 19, 2007 | JVC GR-DVL100 Mini DV Digital Camcorder
Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Mar 19, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Frustrated
E03            TU & SUP REEL FG
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the norma
Dec 09, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
107 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
