Question about Pioneer AVIC-D3 Car DVD Player
I've got a Radiant Double din dvd player. Where doe you connect the Brown Wire(parking brake), Lamp in Wire(pink) and reverse gear wire (orange).. Its an installation for a nissan navara
  • 3 Answers
SOURCE: phase linear double din
hook up a switch solve all your probs, no codes yet **** i will let ya know when i find one.
Posted on Nov 09, 2008
shawnsz
  • 64 Answers
SOURCE: Pioneer AVH P6500DVD/AVIC 80DVD Installed.Pink Purple Green Wire?
can you take the black cage off or maybe you can take a screw driver and bend it back up
Hope this helps
install manual
owners manual
Posted on Feb 19, 2009
dj x
  • 61 Answers
SOURCE: watch a dvd while driving pioneer AVH-P4000 DVD
Hi Dave
No ....go to a hardware store buy a toggle switch than get a single speaker wire (small wire) attach it to the red wire on the back of your pioneer deck (make sure to leave the red wire in back of deck as well) and attach it to the power on the toggle switch do the same with the black wire (ground wire) the black wire will go into the toggle switch under the power wire. finally install the parking break wire from the pioneer unit to the last slot on toggle switch and this should do the trick if not swap the ground spot for the brake spot on toggle switch >>>> MAKE SURE THE TOGGEL SWITCH HAS 3 HOOK UPS to do this correctly (your system will provide sound with the toggle switch off (Blue Screen) but when toggle switch is on you get video while driving) good luck
Posted on Mar 04, 2009
billyd1973
  • 73 Answers
SOURCE: pink wire whats it for, it on a pioneer avic-d2
The brake sensor wire (Lt Green) can be simulated with a toggle switch to ground.
Pink (CAR SPEED SIGNAL INPUT)
The mobile navigation system is connected here to detect the distance
the vehicle travels. Always connect the vehicle’s speed detection
circuit or the ND-PG1 speed pulse generator, sold separately. Failure
to make this connection will increase errors in the location display.
Orange/white
To lighting switch terminal
Light green
Used to detect the ON/OFF status of the parking brake. This lead
must be connected to the power supply side of the parking brake
switch. If this connection is made incorrectly or omitted, certain
functions of your navigation system will be unusable.
Violet/white
(REVERSEGEAR SIGNAL INPUT)
This is connected so that the navigation system can
detect whether the vehicle is moving forwards or
backwards. Connect the violet/white lead to the
lead whose voltage changes when the shift lever is
put in reverse. Unless connected, the sensor may
not detect your vehicle traveling forward/backward
properly, and thus the position of your vehicle
detected by the sensor may be misaligned from the
actual position.
Note: When you use the ND-PG1 speed pulse
generator (sold separately), please make sure
to connect this lead.
When you use a rear view camera, please make
sure to connect this lead. Otherwise you cannot
switch to rear view camera picture.
Further detail can be found here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130AVICD2.PDF
Posted on Feb 24, 2010
  • 66 Answers
SOURCE: i have a pioneer avh-p3200dvd the green wire is
Because there is a sequence you have to use before the picture can show up. You will have to engage then disengage maybe two or three times and wait 1 to 3 secs between intervals. Experiment with different combo's. When the pic comes up you have found the right sequence. It should also tell you in the radio manual the sequence of events you have to do before you see the pic. They do this to prevent you from watching a video while driving your car. SAFETY FEATURE.
Posted on Apr 09, 2010
Common Issues with Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
how can you hook up an aftermarket amp to your Ouku 2 DIN DVD player? i can't figure this out and iv looked everywhere.
Sep 24, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
How do i watch dvds and drive with a pioneer z2 double din
to watch dvds without you having to be in park you have to rewire the wiring to the deck. not the speakerwires or anything like that there should be a pink or orange color wire that comes from the harnest of the back of the deck anyway that wire is the only single wire in its own color besides (red yellow black) these are the wires that give power to your deck. all u have to do is take that one wire left over i think its orange in color and ground it (connect it with the black wiring. that should bypass the brakes from the deck n ypou can watch dvds as you drive but dont forget to also watch the road. :)
Jul 26, 2011 | Pioneer AVIC-Z2 Car DVD Player
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
I doesn't work
gound pink wire in order to make video play
Feb 12, 2009 | Pyle PLTS76U Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Pioneer AVIC-D3 Car DVD Player Logo
216 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
