Question about Poulan Garden
I just purchased a PP208E24 Poulan Pro snow thrower. While operating it for the first time there was a blue arcing between the body of the unit and the chute? What could be wrong? Also is there a service manual anywhere online for this model?
Mine does the same thing. Did you figure any thing out with yours?
Thanks
Posted on Jan 21, 2013
3 Suggested Answers
SOURCE: Electric starter won't engage with the engine.
I have just taken apart my Troy-Bilt Model 5521 so now I can see how all the bits fit together.
The electric starter is a separate device that engages with the cogs on the outside of the engine flywheel.
The cord pull engages the flywheel at the centre.
The fact that the cord pull starts the engine is a good thing.
If you dismantle the blower and take of the top cover (very annoying with many bolts all over the unit, take a look at the spare parts guide to see the exploded view) the starter it comes away with the power cord.
You can plug this in to the main supply and press the start button and you should see the small cogged teeth turning about 200 rpm. Keep your fingers clear.
I am guessing that this is not working at all. Either that or the cog wheel has shaved the teeth off or it is jammed.
This is a good do it yourself project for someone who doesn't mind getting their hands dirty.
It should take about 3 hours to take the unit apar and another 2 to put it back together.
Troy Bilt doesn't sell the starter motor or the engines (mine had an engine seize with a broken main bearing and a broken piston).
I suspect that the resellers don't have these parts either. But someone does.
Good luck
Posted on Dec 22, 2008
SOURCE: tires for troy built snow thrower storm 8526. One
Take your tire to your local tire shop they can install a tube for you i would recomend doing both tires i had this done on my MTD snow thrower
Posted on Oct 28, 2011
I JUST PURCHASED A SINGLE STAGE SNOW THROWER FROM LOWES. WHAT IS THE DIFFERENCE BETWEEN A SINGLE STAGE VS A DUAL OR MULTI STAGE SNOW THROWER THANKS DON DMH8@AOL.COM
a single is just that a single auger that scoops snow and shoots it out chute their a smaller unit --a dual front auger scoops snow into another auger which shoots the snow through the chute the duals are bigger and they move more and heavier snow
Nov 26, 2016 | Garden
Need to decrease Wheel Speed. Blower works well except for this. Keeps plugging up, because it moves to fast.
part of the drive plate. Lift the machine up on it's auger and take the bottom cover off. with the speed lever at its slowest see if the little friction wheel moving linkage can be adjusted so the friction wheel gets as close to the middle of the drive plate as possible. Sometimes it's just an adjustment on the shifter arm.
http://www.ereplacementparts.com/poulan-pp11530es-96192001901-snow-thrower-parts-c-16962_168114_294540.html?page=4
loosen and adjust item 20 and 25
Dec 14, 2015 | Garden
Manual for Poulan Pro Pr300L
Check these guys out...
Have your model # and serial # handy...
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Mar 07, 2015 | Garden
Replace impeller on poulan pro snow thrower
Is this a single stage where you may be calling the paddles an impeller or is it a two stage model? Can you please post the model and serial. I can get you more info and maybe a video.
Best,
Joe
Jan 18, 2015 | Garden
I am unable to start poulan pro snow thrower. Recoil handle will not pull and electric start wont turn over. Brand new machine, never used. Is there a safty mechenism?
have you ever had it running?
you can check the starter, pulll it off and check gear at the end
if teeth are missing the you have to get them off the magnets on the flywheel. they jam it there giving the indications of a set up engine. I ve seen it 2 times
Dec 14, 2013 | Poulan Pro 27" Snow Blower Electric Start
Poulan Pro snow thrower PR8P27ES Brand new and unable to pull recoil handle or turn over with electric start. is anyone aware of a safty mechenism.
no known safety- did you assemble anything? if not- return it. if you did asssemble anything- slowly go back thru in reverse and see if you have a bolt in wrong
Dec 14, 2013 | Poulan Pro 27-Inch 208cc LCT Gas Powered...
I just purchased a Poulan Pro PP208E24 model snowthrower from Costco in Ottawa, ON. I have assembled the unit per the manual. The problem I have is that the unit does not seem to have a neutral position....
According to the manual; remove the klik pin (holds wheel on axle) and place it in the outer axle slot to disengage drive system. Replace klik pin to inner axle slot for normal operation.
Works for me.
Sep 04, 2010 | Garden
Just purchased a Poulan Pro Snow Thrower and on first start after assembly [new gas and 10W30 oil] the engine RPM has a rythemic surges about once a second. When a little choke is applied, the RPM becomes...
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Oct 01, 2009 | Garden
Garden Logo
261 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
