Question about Singer 132QRFB Mechanical Sewing Machine
Machine did not come with manual and I can not figure out how to insert and thread the bobbin at the bottom of the machine in order to start sewing.
    Problem Solver:
  • 4 Answers
Found this manual. Let me know if it the right one. Singer132q manual.
Posted on Nov 13, 2010
I cant figure out the bobbin part getting thread to come up to the needle please help or how to do the whole bobbin thing
Depending on the brand of machine, you insert your bobbin into the bobbin holder, thread the top part of your machine, including the needle, then turn the wheel on the side of the machine by hand and it will catch the thread that is in the bobbin and it will pull it up through the bobbin hole. Once it is pulled up through the hole, near your needle, you will pull the thread towards the back of the machine and leave it. Then start sewing.
Jun 09, 2016 | Sewing Machines
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
I inherided my mothers sewing machine, with no instruction book I can't figure out how to put thread on the bobbin
If, I were you, I would take to Sears, to the sewing machine department and have the salesman show me how to thread it and wind the bobbin. You can order a manual from Sears parts direct, if you don't have it.
Oct 20, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin Threading
Divot on needle must be installed facing bobbin case.
Apr 24, 2017 | Consew 199R-2A Sewing Machine
How to properly thread the bobbin
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin. NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  3. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  4. Slide bobbin cover back into position.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Sep 21, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Singer 132QRFB Mechanical Sewing Machine Logo
26 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
