Question about Masterbuilt 20050106 Propane Smoker
Is it better to put your meat on the top rack of smoker or closer to the water bowl?
  • 8,220 Answers
You want it to be as high up in the cooker as possible so that the smoke will flavor that meat. Low temps and slow smoking is the only way to go. Never have the meat directly over the heat source or it will dry out, have the meat over the pan full of water with beef stock and a little liquid smoke. Don't let that pan go dry. Place an old cast iron pan in the bottom over the flame and add hickory wood to it. Keep the fire real low so the the hickory wood will smolder in that pan. Keep the temp around 200f inside that smoker. Let it go all day. You can do a turkey or a ham or both. Let the ham drip over the turkey or vice-versay. Get a cajun injector and pump that meat full of spices. Just do not be in a hurry. Low and slow is why you bought this cajun microwave right? Use a meat thermometer to verify internal temps as described on meat package. Chill down some beer. When do we eat? I am getting hungry.
Posted on Nov 13, 2010
    Problem Solver:
  • 9 Answers
The top rack of the smoker will give you more smoke flavor since the smoke is allowed to rotate 360 degrees around the meat.
How to cook a brisket. I ahve lost my manual.
Hi judyyates...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
I will also include a link that will interest you below.
Please take time to rate me.
http://www.smoker-cooking.com/howtosmokeabrisket.html
Sep 24, 2011 | Brinkmann Sportsman Charcoal Double-Grill...
How do I smoke in this Smoker/Grill? Like where do I put the Smoker chips there is no smoker chip box, just the pan for the charcoal and a pan I think for water.
Hi karin 1967...
Sep 24, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
How to slow cook food on a char-broil smoker, model CBBA-2750. (what temperature and length of time as well as instructions on how to cook)
Hi hcf6886...
Sep 18, 2011 | Grilling
How to use a char-broil smoker (charcoal) with wood chips smoking briskit. ( what temature should the grill be at ?)
Hi hcf6886...
There are not directions on how to use the smoker. Do you have have any instructions on using the masterbuilt smoker model 20020611
Hi dan480volts...
Maybe this will help you
Sep 16, 2011 | Masterbuilt 20050106 Propane Smoker
Do you put the wood chips directly on the heating element?
Hi bobsbbq3u...
I am sending you some smoking information on how to use your smoker..
Sep 07, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I put the charcoal in the bottom bowl in the smoker. what do u put in the top bowl right above that? i am making beef jerkey
Hi there....the top bowl which is smaller than the charcoal bowl is primarily for water to keep moisture in the roasting environment while cooking..I don't think you want to add miosture to make jerky...I have a Ronco food dehydrator for that...I only use my smoker for slow cooking and roasting/smoking large peices of meat..I hope this was helpful.....
Sep 05, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
I have never had a smoker before is the water pan the bottom one or is that the wood chip pan?
Hi
3...Start a fire in the smoker having the fire below the meat, but wait to put the meat on till the flames (if any) subside.
Use the water pan below the meat (if you use one) to catch the juices from the meat...it will be above the pan with the charcoal in it.
Use hardwood or charcoal for your fire/smoke,
Once the charcoal/wood are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat, if you do not use a water pan.
Monitor the tempreture
Sep 04, 2011 | Grilling
When do I need to put water in the water bowl? and how much?
You will not use water for everything you smoke. However, the water bowl must be in place whether you're using water as a moisturizer or not. The water bowl goes on the lowest rack holder. If you are using water for as a moisturizer for a specific meat or fowl, the bowl should initially be 3/4's full.
In case you have misplaced your Owners Manual, I have included a link to it. You can download and print it for future reference. I have to admit, as far as Owners Manuals or Guides go, it's not very thorough.
http://www.masterbuilt.com/pdf/manuals/07092010%2020070910%20Manual.pdf
Apr 13, 2011 | Masterbuilt 20070106 Electric Smoker
The difference between the flame bowl and water bowl
You want the wood chips above the heat source and then the liquid above that. The heat source smolders the wood whilst the liquid keeps the meat moist. Remember you want a very low heat.
Dec 31, 2009 | Masterbuilt 20050106 Propane Smoker
Masterbuilt 20050106 Propane Smoker Logo
319 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
