Question about Intel ASUS P4SC Socket 478 Pentium 4 Motherboard w/ Audio LAN - P4SC-LAN-DP
No sound no ethernet connection after installing windows xp my mobo is socket 478 i dont know what's the brand of my mobo could somebody help me
sandrew
  • 2961 Answers
SOURCE: Viper MSNV-939 ATX Socket 939
I assume you have tried with only one stick of ram individually at a time if you are using two to check it's not the ram as one faulty can cause the system to stop. Also assuming you bought the ram from the same place and is compatible with the board. Sometimes people also forget that the processor in some cases has to be powered by the 4 pin plug from the PSU and not just from the ZIF socket that older processors use to power up, so double check the manual. The other main common cause of the this problem is when you are putting together all the hardware onto the board, if you don't protect it underneath it may have overflexed the board and shorted or damaged the circuitry or the bios chip. That's not to say that the motherboard was'nt faulty in the first place.
Posted on Apr 18, 2007
  • 231 Answers
SOURCE: cannot install windows
Hi, check what amount of RAM you have. XP can be loaded at 28Mgb of RAM but is more succesful at 256Mgb which is the recomended minimum. The ideal amount of RAM for XP is 512Mgb and I believe you can never have too much RAM.
Regards mistyman
Posted on Feb 19, 2008
  • 71 Answers
SOURCE: i dont have ethernet connection :c
this might help you : intel d915GAG downloads
Posted on Oct 31, 2008
  • 35 Answers
SOURCE: i put a used e210882 socket 478 motherboard into my computer
It is probably asking you to insert an XP disk, as Windows XP will need to install the new drivers for your new motherboard.  It will also give you the option to select a folder (this is what you are seeing) already on your hard drive that would contain the proper drivers for that motherboard.  Chances are this folder does not contain the proper drivers.  You will need an XP disk to install these drivers.  Boot with the XP disk in, and chances are Windows will take care of everything else.  If you do not have the XP disk you used to originally install Windows on that machine, then you can use a seperate PC to get the drivers required.  You will need to visit the website of the manufacturer (I believe emachines is your new mobo?) and download the drivers.  Then save them to disk.  When booting into your new system, make sure this new disk (you made from other pc) is in the drive, and then select that drive when it asks you for the folder you are talking about.  This will then install the proper drivers and you will be up and running shortly.  Hope this helps :)
Posted on Jan 01, 2009
SOURCE: AUS P4S533-TVM Socket 478
how to download motherboard drivers
Posted on Feb 20, 2009
Have a 2005 a1250n Hp computer with Hp ver XP SP3 OS installed. MOBO failed. Can it be replaced by same p/n 5188 1936 using current all ready loaded XP OS. Will GUID be a problem?
If you can get the exact mobo you may replace it. No driver issue will raise. You can also buy a new mobo with same chipset and replace it. Same chipset mobo will require to install Sound, ethernet and vga drivers
Apr 12, 2016 | HP Computers & Internet
The network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
No audio
ok. post your computer model number example=t2080, producer eg=emachine, hp, dell........, I cam help you when you post all this to the forum and to my email to notify me. innocent.asia@yahoo.com
Jun 13, 2008 | Computers & Internet
No audio
i need to help.
my motheboad have audio problem,
i need audio device for install.
sis mother board, 5595 chip
Jan 30, 2008 | SIS741GX-MN Motherboard
Matsonic ms9158ep sound drivers
plz mother board matsonic ms9158ep sound driver free down load
Dec 19, 2007 | Matsonic MS9158EP (DSMTSMS9158EP)...
No sound
Did you check the device manager?
If there is yellow question mark or a red exclamation mark. You need the correct or re-install drivers.
Let me know...
Dec 07, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
Add on lards not been dtected in add on in xp
That is an EPOX EP-4BDAV2 478 Mobo motherboard.
Rate me SOLVED
Nov 23, 2007 | Intel Motherboard
Intel ASUS P4SC Socket 478 Pentium 4 Motherboard w/ Audio LAN - P4SC-LAN-DP Logo
49 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
