Question about HP PhotoSmart M627 Digital Camera
Images are so bright when taken outdoors
The images taken from my HP Photosmart M627 appears to be so bright especially when taken outdoors and that sometimes you cant see any images already. When you zoom in the images taken you can see horizontal lines. All settings were checked & set to default.
  • meela May 11, 2010
    I deleted all my family pics by mistake last Friday. Is there any way you can help me to retrieve them? I am so grateful to you. Thanks in advance.
My camera is Kodak Easyshare V803
Posted on Jun 18, 2008
My camera shoots too bright images when shooting outdoors. Photos taken indoors appear to have horizontal lines but are much clearer than those taken outdoors. Is the shutter stuck or is it a ccd prob
With the main dial on top of the camera, set it on Auto(magic). When it is in a scene mode, it can't adjust to the right settings.
Use the menu button.
When it is set to Auto and you get the same result, I'm afraid there is another problem. But if the pictures are better, only use a mode you understand. (To start with scene and chose a mode you need)
Sep 26, 2014 | Samsung Digimax S630 Digital Camera
I bought a SanDisk 4 GB and my HP photosmart M627 will not format the memory card
The M627 works with SD cards. Your 4GB card is an SDHC card and will not work with this camera. You need to use SD cards, 2GB and smaller.
Jul 29, 2011 | HP PhotoSmart M627 Digital Camera
When i take a photo in day time images becomes very brigh
the camera,diaphram is defective so bright light exposes,will be over exposed.
Mar 24, 2010 | HP Photosmart M527 Digital Camera
Overexposure and horizontal-striped image
Hi!
No, it's not a software problem. The problem is that the shutter doesn't work so it can't control the amount of light taken so the pictures are very bright with horizontal lines. There are usualy two causes - a broken shutter cable inside the lens or the shuuter blades are stuck - may happen if the lens get wet or something adhesive gets in it. It's a hardware problem so I suggest you contact local Canon or other camera service center. It is considered a hard repair so it could get expensive. I don't think it's worth it, so I would suggest you get another camera.
Hope this helps!
Tom
Jul 29, 2009 | Canon PowerShot A420 Digital Camera
Screen does not show images
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Too bright with lines too. My camera shoots too bright images when shooting outdoors. Photos taken indoors appear to have horizontal lines
it is a possible CCD FAILURE !
u are covered dont worry it is a manufac fault inn CCD's ur camera manufacturer will do it Free of charge pls see the link and call them and PLS RATE ME FIXYA for help
http://www.imaging-resource.com/badccds.html
dont worry if u are not on list just call them !
pls dont forget to rate me
May 07, 2009 | Samsung Cameras
Bright images outdoors, sometimes with horizontal lines
CCD Failure !!
u are lucky get it repaired free of charge postage paid just call Canon in ur area and they will do it see link below and Pls rate me FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Apr 23, 2009 | Canon PowerShot A460 Digital Camera
Camara hp m627
la camara cuando enciende dice error lens: m627-30 que significa eso y como puedo repararla
Jul 09, 2008 | HP PhotoSmart M627 Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Open Questions:
See all HP PhotoSmart M627 Digital Camera Questions
HP PhotoSmart M627 Digital Camera Logo
101 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
