Question about Samsung Digimax D53 Digital Camera
I've tried multiple cards and always get the "Card
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 23, 2010
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
Canon g9 just started getting card locked error. I checked, the card is not locked - also tried different cards. It works sometimes. Tried to reset the settings and received "busy" message.
Check the right strap lug and see if it is loose. It is a well know problem with the G9 that the screws that hold it onto the top cover come lose and fall into the camera, causing many different problems is they short out parts of the circuit
Feb 17, 2013 | Canon PowerShot G9 Digital Camera
Canon SD1300 memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
Dec 06, 2011 | Canon PowerShot SD1300 IS IXUS 105...
THe main screen reads "card
try to look at the side of the card it might be locked then unlock it
Jun 28, 2011 | Samsung S860 Digital Camera
My camera suddenly had the message "card locked!".
If this camera uses SD cards then what may be happening is that the little lever that drops into the slot on the side of the card to indicate locked or unlocked is jammed in the locked position. If you shine a flashlight in you might be able to see where the pin is.
May 05, 2011 | Canon PowerShot SD880 IS Digital Camera
A message always shows "MEMORY CARD IS WRITE
If you take out the memory card and look at it... it has a little button on the side... slide it over.... and then slap it back in the camera and that should take care of the problem.
You can also get the memory card locked/protected message if you are trying to use a SDHC card in a camera that does not support High Capacity (HC). High Capacity is any SD card with over 2GB of memory space.
Hope this helps.
Apr 26, 2011 | Nikon COOLPIX L4 Digital Camera
Casio exilim ex-80 always shows SD card as locked
the SD card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit of plastic sticking out over where the card's locking switch would fit when the card's inserted.
Oct 25, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
My sony ericsson k530i cant accept my sim card. Always gives the message "Insert correct USIM"
It's possible your phone is locked to a specific sim card. If you got that phone from a telecommunications company for example AT&T, you will have to contact them..
have you also tried other sim cards on your phone? just to rule out if it's a problem with the sim card or the phone..
May 09, 2009 | Sony Ericsson K530i Cellular Phone
Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Samsung Digimax D53 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
