Question about VeriFone Omni 3700
The machine Omni 3740 doesn't allow transactions to process through the phone line. All the program lights are lit and the date is the proper one. 1) It was disconnected for a month for a move. I have tried all three ports in the back, but I am not sure which one of them is the proper solution can you help and 2) if it was disconnected for so long is there something else I need to do to get it to work properly. Thank you.
  • VeriFone Expert
  • 113 Answers
The machine Omni 3740 doesn't - ube1jiq9nqqaaaabjru5erkjggg==HOPE THIS HELP IF YOU NEED MORE HELP CALL US @ 775- 358-2922
Posted on Dec 12, 2011
  • Mario. S. Dec 12, 2011
    pictures posting not showing call we can help
We can't get the machine, OMNI 3740, to do a settlement says on ticket NO HOST FOUND, what do we need to do
No host means no phone line on connectivity. check wiring and make sure there is a dial tone if plugged into a phone line.
Feb 02, 2015 | Retail Supplies
No card for transation
One if not too late. This terminal is out of compliance with running credit cards through. But if your merchant service provider is allowing you to continue then at the main screen just:
Hit 1
Then enter CC # and enter or function.
Then EXP date of the card then function.
Then Address and or ZIP of the billing for the cardholder
then enter and it should process it VIA dial approval line.
Jun 05, 2009 | VeriFone TRANZ 380 Transaction System (X2,...
Omni 3740 SYS Mode file group 1 password?
Where did you purchase the machine from? Or do you know what companies have downloaded onto it previously? They must have changed it at some point.
Jun 02, 2009 | VeriFone Omni 3700
Verifone VX510
Yes he is somewhat correct. At the main sale screen hit the option 6 usually the password is 1 Alpha Alpha 66831 if it gets you to the Terminal Phone COMMs screen it is good. Choose phone then next and choose PBX code that is what needs to be dialed out from your phone system to get an outside line IE: 9,,8,... once that is edited choose enter then exit if that doesnt work at teh main screen hit the more key or the tip key until you see other setup then the password again. 1 ALPHA ALPHA 66831 hit the tip or more key again until you see COMMS. Select it then hit next until you see baud rate hit edit and that field and then next until you see 300 hit enter then exit save changes hit ok then the red X key to get back to the sale screen try that.
Other fixes as well but it needs phone conversation.
Call me at www.greenlightpayments.com ext 105
Jan 04, 2009 | VeriFone Omni 3700
BECOME the loyalty card processor
There are two parts to this problem: 1) actually processing transactions, and 2) all the cards "out in the wild".
Prairie Trail Software sells host software that can process the transactions for you. It would be a custom solution.
However to get the data on all those existing cards will be the problem. You will need to get reports from your current processor that give you all the data about those cards in the wild. If you can not get those reports, then you are not able to transfer all those existing cards (and histories and account balances). In that case, you would need to replace those cards and run side by side until you can get most of them replaced.
Dec 18, 2008 | VeriFone Omni 3700
3750 fails to complete transaction
it needs to reprogram the machine
erase all of Memory and cache
ask your processing company, build NEW terminal file
and install fresh one.
Sep 25, 2008 | VeriFone Omni 3700
Verifone omni 3740
Most likely:
1, alpha, alpha (little gray button between the four purple keys), 66831, enter
Sep 23, 2008 | VeriFone Omni 3700
Verifone omni 3750
here's some passwords you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jul 09, 2008 | VeriFone Omni 3700
VERIFONE OMNI 3740 INK RIBBON
We found that it was neither the thermal paper roll nor the thermal component. The cover did not close tight enough and that caused the print-put to be light or missing printed areas.
Jan 04, 2008 | VeriFone (M19755014US1) Magnetic Card...
Retail Supplies Logo
61 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
