Question about Your One Source Homeline Load Center, 200 Amp
How do i know which breaker goes where into my house.
  • 885 Answers
If the installer didn't fill in the label inside the door you're relegated to turning one off and checking what turns off in the house. You can do this by yourself but it's a lot easier with someone in the house to tell you what shut off as you switch off each breaker in the box. Use things like plug-in lamps or hair dryers in outlets to know when they go dead.
Posted on Nov 13, 2010
Why are my house lights and appliances occasionally flashing on and off?
If it's only happening in one section of the house, it's more than likely the breaker that controls that section shorting out and needs to be replaced. If it's happening throughout the house, chances are, it's the main breaker that's shorting out. The least that can happen when it goes, is you'll be sitting in the dark. The worst that can happen, is it can burst into flames, burn your house down and leave you camping in the park.
They aren't that hard to replace. Once you've removed the face plate from the breaker panel, most breakers can be removed by pulling out on the bottom of them and then lifting them up and out. Once they are unplugged, they are harmless. Loosen the screw that's holding the wire or wires, remove the breaker from them and replace it with a new on. DO NOT ALLOW THE WIRES TO TOUCH ANYTHING IN THE BREAKER BOX!!!!! Once you've re-attached the wires, hook the top of the breaker in place and them snap the bottom back in. Be very careful not to touch ANY metal what so ever while doing the removal or installation of the breakers. replace the breaker cover and switch the new breaker on. See? Now wasn't that simple??? LOL! Best of luck to you. I hope I helped at least some.
Bill
Aug 24, 2014 | Cars & Trucks
Turning off breaker
Locate the breaker box, turn on the dryer, flip breakers off and on till you find the one that stops the dryer.
Write on the breaker box with a magic marker to identify each breaker. You can do this with all the breakers! Turn on everything in the house...lights, microwave, etc. ..Just need someone to tell you what goes off when you turn off each breaker and you write it on the breaker box!
Jul 26, 2014 | Dryers
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
I want to know what amperage it is to install the right circuit breaker
Dont burn your house down just to get your vacuum to work circuit breakers protect the wire in your house 14gauge wire needs15 amp breaker 12 gauge wire need 20 amp breaker
Feb 27, 2011 | Vacuums
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
My central heating unit is in the attic of my 2bd/2bth house. I don't know its age. It's a gas unit, but doesn't have a constant pilot flame. Rather, the pilot is ignited electronically. The problem is...
You don't mention make or model so here is my guess as to how to thinkout the trouble of what ever is in your attic.
For some reason, your heater is mis-firing. Normally, I would expect 3 to 5 such events at which time the heater goes out on safety. The heater knows it is on safety but you don't until it gets cold in your house. When you turn the power off, wait the 30 seconds, turn it back on, the heater no longer knows it is on safety (memory cleared) so it fires. Your heater continues to fire until ? at which time it starts counting again to 3 or some number. At the max mis-fire number - it goes out on safety again ... repeat - turn it off, wait 30 seconds, turn it back on - no memory and so forth.
Do you have a service contract or regular service man? Might be time to find one.
Thanks for your question at FixYa.com
Jan 05, 2010 | Heating & Cooling
I need 2 Homline SQD single pole 40 amp breakers any idea wher to get them in the Twin Cities Mn area
Your best bet is to go to an electrical supply house.Look in your yellow pages. I wonder why you need a 40 amp single pole breaker. After 30 amps, most everthing goes to 220v (two pole) ?
Oct 14, 2009 | Your One Source Homeline Circuit Breaker
I would like to know if I can power my hottub right to an existing 220 line the tub runs 220 volts 36 amps and I have a 40 amp fuse already installed in the house plug
Check your local codes, you probably will need a ground fault current interrupting breaker(GFCI). Do not skip the codes, if anything goes wrong, your insurance company will not cover. Putting a special box GFCI protected will give you extra protected outlets for outside use.
May 05, 2009 | Electrical Supplies
Pool motor wiring
I assume you mean a gfci recepticle? If this is the case you need to take the black wire from the house and pigtail it to go to both the recepticle (Black / Line) and one line side screw of the switch. The white wire from the house goes directly to the line/white side of the recepticle. Also pigtail the ground to go to the green screw on the recepticle, the green screw on the switch, the green wire from the motor, and the ground screw on whatever box you're using. When you purchase the switch make sure you get a two pole switch rated for at least the amperage of the motor. The red wire from the house and the black wire from the pigtailed black will go to the two line side screws of that switch. The red and black from the motor will go to the two screws on the load side of that switch. Make sure to ground everything properly being so close to water. The cover needs to be sealed securely and I recommend the cover that has the lever to activate the switch as opposed to the little door over the switch handle. Also make sure the two breakers supplying those two circuits have a handle that turns them both off at the same time.
Sep 01, 2008 | Energizer Rechargable Battery with Charger
Won't power on
U have only 120 vac, need 240 vac. Turn the 30 amp breakers hard to off then back on. Should do the trick
Apr 29, 2008 | Kenmore Elite HE4 Electric Dryer
Your One Source Homeline Load Center, 200 Amp Logo
60 people viewed this question
Top Your One Source Electrical Supplies Experts
Steve
Lisa
Lisa
ray gallant
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
