Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
My line 6 doesnt turn on,its like no electricity is going through it? i would like to know what is the problem???
    Problem Solver:
  • 10 Answers
I can't find a schematic but there should be a circuit breaker or a fuse on the backside of the amp.
Posted on Nov 14, 2010
How do I find a local line 6 certified repair shop?
just go to "Google search" and type in local line 6 dealer. might want put in your address as well. Guitar Center handles them and can help you out if there's one close by
Sep 17, 2014 | Line 6 James Tyler Variax JTV-59 Modeling...
Trying to look up serial number for 6 string electric guitar
It would help if you told us more about:
1.) What do you want to know about this guitar?
Nov 26, 2013 | Peavey Music
My line 6 amp has blown. I havent used it alot and when i do use it I never turn it up very loud. I think i pugged it into a bad electrical socket. I plugged it in and turned it on and the volume shot up...
Is it potentially fixable, but probably not worth it. By the time you have paid for spares and an engineer to fix it it would be more than the amp is worth. If it is within warranty then take it back to the shop. It may well have been a fault with the amp.
Sep 15, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
My boss line selector doesnt switch channels anymore, is the switch gone or can it just be dirty insude ?
Could be either. The switches can either get dirty contacts or parts can break within the switch. If you suspect dirt, try to get some CRC226 into the workings. You can get it at Home Depot in the electrical department. Use ONLY this product as there are other CRC products there as well.
Feb 25, 2011 | Boss LS2 Line Selector Pedal Switch
The Master Volume control on my Line 6 Flextone II Head is scratchy-noisy when I turn up the volume. I am looking for a replacement, but, Line 6 does not have it on their replacement parts site. The phone...
First try spraying a bit of CRC226 (aaaaaa9make sure it is 226 as there are other products with similar numbers there)available at Home Depot in the electrical dept. into the control where the leads go into it. You may need to bend the plastic spout of the spray can at 90 degrees near the end to get it to go up into the control. This has a high probability to solve your problem.
Getting replacement controls that exactly fit are a major headache from anyplace than the original manufacturer.
Aug 27, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
When you 1st buy the amp when u turn it on it always starts on the Insane Channel when i turn my own now it starts on the Clean Channel and gives no sound on any channel and when the cable is not connected...
The post at this site might help:http://line6.com/community/message/59307 Also this chart if you don't have it:http://bx.line6.com/spiderii/pdf/spider2_settings.pdf Try doing the reset first and if that doesn't work try contacting them. Did this help?
Oct 23, 2009 | Line 6 Spider Iii 30
I don't know....
As you know, when you plug in your headphones, the amplifier cuts the sound to the external speaker, routing the signal through your headphones instead.
When you accidentally pulled the headphone plug from the jack, it apparently damaged the jack, which has the relay attached that routes the sound to your headphones.
Replace the jack, and everything may be OK. I say may be, because the jack is attached to a circuit board in these line 6 ampllifiers, and if you have damaged the circuit board, you will have to send it to line 6 to be repaired.
The downside is if it is not under warranty, it is an out of pocket expense, and Line 6 will not even give an approximation on how much a fix will cost. I have gone through it with Line 6 in the past, so I am very aware of the procedure. It is also a limited warranty, and they may not cover this particular damage.
However, if you are straight with them and they feel obliging, they may fix it under the warranty, if it is still active on your amp.
I had a spider 2 x 12, which was switching between amp models by itself, and they told me that because it was not under warranty, that I might want to consider NOT sending it to them, and just buying another amp. I didn't like that advice, because they seemed as though they didn't care about retaining my business.
Now, something to consider is taking it to a reputable amp repair shop (preferably one that is Line 6 authorized), and see what they can do. Maybe your clip is just bent, not allowing it to spring back from the contact switch that cuts off the main speaker. It could be a very inexpensive fix, but you need to have a shop actually take a look at it up close and personal.
Good luck. I, for the most part, enjoy Line 6 products, and their excellent distortions. Just remember, their amps tend to have a LOT of problems. You can find sites that list many many dissatisfied Line 6 amp owners. All that electronics (on board effects, soft buttons and switches, etc.,) make them vulnerable.
Now I mainly use my old reliable Marshall 1/2 stack with my Line 6 pod, as well as quite a few other pedals.
You would be amazed by the fact that you can still get pretty good money for a broken line 6 amp, maybe get something with less bells and whistles to break, and go with off-board effects pedals and processors.
Please excuse me for adding my own opinions, I am quite well versed in this type of advice having grown up in a luthier / guitar shop and have been playing for 38 years.
Good luck with everything, and if all goes right, adn it is just bent, it may cost you as little as a few dollars to fix. I'll keep my fingers crossed for you.
Thank you for using FixYa.
Sep 09, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
No power is going to my amp
This sounds like there may be something loose inside of the amp. Please dont go pokeing around in side there your self. Unless you are a fix it kind of person. There could be electric charges , even if it has been unpluged for days. Have some ck. it out if you can not. I bet ya its not to serious , all so ck the fuse. Some times they will play around just befor they blow out for good . keep on playing DFD
Mar 29, 2009 | Line 6 Spider Iii 30
I'm looking for the variax 700 acoustic manual
Go to the Line 6 website <line6.com> and go to support, downloads. The manual is available in pdf format there.
Mar 27, 2009 | Line 6 Variax 700 6 String Modeling Guitar...
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
143 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
