Question about Frigidaire FRS26R4A Side by Side Refrigerator
The freezer side was not cooling and water had leaked all over the floor.A friend suggested unpougging fridge. I did and it works again. Any reasens why?
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Nov 14, 2010
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
MAYTAG MSD2734GE side-by-side fridge/freezer. The freezer coils on a regular basis (3-6 weeks intervals) will freeze. We will have to remove the coil covers and manually defrost them before it will...
I have written tips pertaining to each of those 2 issues
Drian blocked tip...http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
Evap. coil freezing up tip...http://www.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
i have 2 pictures in the coil freezing up tip and they always for some reason post incorrectly so here they are..oldtech2332_43.jpgoldtech2332_44.jpg
Aug 22, 2011 | Maytag MSD2734GE Side by Side Refrigerator
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
Samsung fridge is leaking water
Probably one of the plastic tubes under the refrigerator is leaking.
Apr 04, 2009 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
