Question about Mr. Coffee MRCTB Coffee Maker
Water inside boils, thermostat set to minimun, does not shut off. Would like to purchase new thermostat. Newco?
Bunn coffee maker will not quit boiling the water in the tank, what is the solution?
It sounds like the thermostat needs to be change. it is located under the top of the unit. Should be on the left side under the lid. Visit this link to get an idea of the part..http://www.ereplacementparts.com/thermostat-kit-p-847667.html.
Nov 22, 2014 | Bunn VPR Coffee Maker
Can a person buy a bad new thermostat
Yes, it's been known to happen. Can test it by putting in a pan of hot water on the stove. Just before the water starts to boil thermostat should start opening. When the water does boil, thermostat should be fully open.
Sep 11, 2013 | Cars & Trucks
Removed my thermostat and tested it in boiling water and it was opening correctly so I re-installed it. After that the water in the radiator boils, and move to the reserve tank, without the electric fans...
your cooling sustem is airbound.i suspect you have little or no warm air coming out of heater.while filling with engine running remove outlet heater hosefrom heater core.this alone will purge 90% of air from system.
Jan 21, 2011 | 2001 Nissan Sentra
How to install thermostat
The best thing to do is to buy a Haynes or Chilton manual for your vehicle.
Purchase the replacement thermostat and gasket (no they do not come as a set.)
Items needed: socket and ratchet, a tube of liquid gasket, a wire brush, screwdriver for hose clamp
Open the hood, disconnect the Neg terminal of the battery (not the red one)
The radiator accept hot water at the top and feeds it to the water pump on the bottom.
Most thermostats are located on the engine block at the other end of the water hose going to the top of the radiator.
Trace it back, and remove the hose clamp.
Pull the hose clamp back (you do not need to take it off)
Pull the hose off the thermostat hosing neck.
The housing will be held on by 2 or 3 bolts, remove the bolts to remove the housing
BEWARE OF THE ORIENTATION OF THE .THERMOSTAT
The thermostat should come loose.
There will be gasket material stuck to the housing and the engine block, it must be scraped off before installing the new gasket.
Compare old thermostat with new one. Make sure they match.
A good tip is to stress the new thermostat in boiling water to insure it works. Boils some water, and place the thermostat in the water and watch it open. pour out the water, run it under cold water to cool it off.
After using a wire brush to remove the old gasket material,
place liquid gasket along the edge of the engine block opening and place the new gasket on the opening.'
Place the new thermostat in place (IT MUST GO IN ONE WAY)
Place the housing back on the engine block and replace the bolts, (tighten the bolts gradually )
replace the hose on the neck, and replace the clamp and tighten.
remove all tools and reconnect the battery
Good luck and don't forget to vote.
Oct 12, 2010 | 2001 Ford Windstar
Water in resovoir boils away. Do I need a thermostat?
Listen to the unit after you make a pot of coffee. You will hear it start heating the water and then after the water heats up you will hear the unit shut down. If it is not shutting down and is continuing to run then yes you need a new thermostat.
Dec 02, 2009 | Bunn VPS Coffee Maker
I have a 3 burner that I got on ebay and it seems to want to get the water too hot. It gets hot enough that it sends steam from everywhere. I imagine that that is due to water boiling in the tank? I...
Hello, yes you are correct, it's due to the water boiling in the tank. take 2 screws out of the top panel, just under this panel you will find the thermostat (it's ajustable) turn the temp down on the thermostat, if this does not solve the problem your thermostat may be bad and you will have to replace it. You can purchase new parts from either bunn direct or from holiday house in california. if you have any additional questions please feel free to comment again. Good Luck! Mike
Oct 16, 2009 | Bunn VPR Coffee Maker
Water boiling back in the resevoir after running 10 min thermostat is new and so are hoses. then car starts to run bad and shuts off.
Sounds like a plugged radiator or bad water pump, assuming the thermostat was put in correctly. If you hear a loud whining noise from the water pump when running, that's probably the problem, and it's more common than bad radiators.
Sep 28, 2009 | 1995 Dodge Neon
Mr. Coffee MRCTB Coffee Maker Logo
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
