Question about Cameras
Can I down load a operating manual for a QV-R61 camera please
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
You can download a PDF copy of the manual from the manufacturer's web site at
http://support.casio.com/manualfile.php?rgn=1&cid=001010064
Posted on Nov 13, 2010
My casio qv r61 takes pics but they are coming out mostly white whats up with it can it be mended
It is possible that one of the settings is not correct for normal pictures. I don't have a menu walkthrough for your model, but here is a few things you can check:
1. ISO - This is how sensitive the camera is to light. You probably want it set to a lower number or preferably Auto. If its set at 400 or above it can cause wash out in bright lighting.
2. EV / Exposure Value. You can usually adjust the exposure value in increments of .5 or .33 from -2 to 2. If it is set towards two it can cause over exposure and odd coloring.
3. WB / White balance - This lets you set custom or preset colors as the base "white". Make sure its not set to custom and it is set to something appropriate for your environment (auto is best if available).
4. Also make sure the camera isn't set to long exposure or night mode as both of these settings can cause washout.
Please leave feedback if this was helpful. Thanks.
Apr 16, 2011 | Casio QV-R61 Digital Camera
Tip
Unbelievable I have a QV-R61 that had frozen with the lense out and blank...
Surprisingly enough, most freezing problems (and other problems, too) can be solved by gently hitting your camera. It works! Just remember to be gentle.
on Jul 11, 2008 | Konica Minolta DiMAGE G400 Digital Camera
I wud like 2 format another memory card in my qv-r61 but wen i put the card in i can get nothing onscreen to set it up any ideas? it is a Fuji memory card and when put in the camera all i have got onscreen...
Hi, have you tried using your computer to format the memory card, what you need to do is put your memory card into a memory card reader then wait a minute then open up my computer then locate the memory card then right click on it with the right button on the mouse then choose format and format it to fat32 then try it in your camera and it should then be working.
if you have been using a memory card in the camera and still have it then put this in the memory card reader and go to my computer and then right click on the memory card and select properties and have a look at what format that memory card is, and if its anything other than fat32 write down what it is.
Then put the new memory card into your card reader and goto my computer then right click with the mouse then choose format and then choose to format it to the same type as the other memory card thay you know works in the camera, once you have done this the memory card should work in the camera with no problems.
until you have formatted the memory card to the correct type it wont be recognised by your camera so give it a try what i said and you should find you will have no more problems ok.
let me know if you need further assistance ok
Jul 02, 2010 | Casio QV-R61 Digital Camera
Battery cover broken
don,t bother looking at this site as it gives no solution to any problems
Apr 04, 2010 | Casio QV-R61 Digital Camera
The flash will not operate on my casio qv-r61
open menu,select the flash section,select fill flash/auto flash,and try for flash.
Mar 16, 2010 | Casio QV-R61 Digital Camera
System error 0e01
Maximale Kapazität von SD-Speicherkarten bei Verwendung mit CASIO Digitalkameras Error 0e01: It has to do with the maximum save capacity of the used SD-Cards (max. 1GB for following models). You can format the card (somehow, maybe with docking station), then it would only have 1GB capacity...
...found on Casio Homepage...
Bitte beachten Sie, dass die folgenden CASIO Digitalkameras die Verwendung von SD-Speicherkarten mit Kapazitäten von mehr als 1 GB nicht unterstützen. Bitte berücksichtigen Sie dies beim Kauf von SD-Speicherkarten für diese Kameramodelle.
CASIO kann nicht für die ordnungsgemäße Funktion von SD-Speicherkarten in den Kameras garantieren, auch wenn die Kapazität der Speicherkarte 1 GB nicht überschreitet.
Für welche Modelle ist dies gültig?
  • QV-R3
  • QV-R4
  • QV-R40
  • QV-R41
  • QV-R51
  • QV-R52
  • QV-R61
  • QV-R62
  • EX-S1
  • EX-S2
  • EX-S3
  • EX-S20
  • EX-S20U
  • EX-S100
  • EX-M1
  • EX-M2
  • EX-M20
  • EX-M20U
  • EX-Z3
  • EX-Z4
  • EX-Z4U
  • EX-Z30
  • EX-Z40
  • EX-Z50
  • EX-Z55
  • EX-P600
  • EX-P700
Welche Probleme können auftreten?
  • Die Fehlermeldung "CARD ERROR" wird auf dem Bildschirm angezeigt. Die Aufnahme von Bildern ist nicht möglich.
  • Wird die Speicherkarte in der Kamera formatiert, reduziert sich die Speicherkapazität auf ca. 1 GB.
Jun 08, 2008 | Casio Exilim EX-Z40 Digital Camera
Zoom turns my camera off
my camera turns itself of, when i only want to make a photo or a video... i can see the photos i took, but then when i want to switch to the photo/video-making-option my camera says "low battery" and then it's off...
would be nice when someone can help me with my problem
Mar 20, 2008 | Casio QV-R61 Digital Camera
Casio qv-r61
Hi I took my QV-R61 to the Casio Authorised service center. The lines problem has been diagnosed as a defective CCD image sensor and the the cost of replacing this (Rs 7K) is almost the cost of a new camera!! Too bad this camera is now useless!
MK
Dec 02, 2007 | Casio QV-R61 Digital Camera
I dont get sound in movie recording, what do i do?
its simple this camera don't have audio recording That all.
Oct 28, 2007 | Casio QV-R61 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
