Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
My machine doesn't brew - the water doesn't flow through: why?
I have a 12 cup programmable cuasinart coffee pot sometimes when i turn it on it will brew right away and sometimes it takes forever to brew. what could be the problem?
Posted on Nov 17, 2010
I have a saeco super automatica Leaking water
Take the brew unit out when the machine is off and cold. With your finger, check the well next to the large gear on the inside of the machine. This is the gear that fits in the back of the brew unit when it is in place. That well may be clogged with fine coffee grounds and some mildew build up. You might notice that after brewing, very little water will has been flowing into the drip tray. Take a Q-tip and push it through the hole at the bottom of the well to remove the coffee ground buildup. The excess water after brewing will flow through normally now and not behind the brew unit.
Mar 02, 2017 | Saeco Coffee Makers & Espresso Machines
Ours does not finish cycle either!!! The machine runs through the cycle up until the point where water should enter the "brew group". The coffee doesn't come out. What shall we try?
I just fix that problem by opening the water flow meter by some coffee grinds, also had a little coffe grind jamming a check valve that is at last of the water pump flow, now is running pretty well
Dec 20, 2012 | Saeco Easy Espresso Machine
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
After the coffee is ground and pressed, no water goes through to brew the coffee and dispense it
Sounds like the brew unit is blocked, to be sure try this, use the pre grounds button to brew a coffee, if no water comes out then it is the brew unit, remove unit and look under red o-ring, you will see a shower screen, clean shower and tube that flows to the discharge(top, you will have to remove the 2 screws up there, be careful not to lose the small plastic ball under the spring). Reassemble and try again.
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
I have a Saeco Magic De Luxe. I am having a problem intermittent
Could be the pump not providing enough pressure to force the water through the coffee. When using beans or preground, can you still hear the pump function?
Jun 30, 2009 | Saeco Magic De Luxe Espresso Machine
Water pump?
If you could brewer coffee or get hot water out of the steam wand then it could be the one way valve on the bottom of the water tank. If you are running the pump output into a glass then it is probably scaled up in the boiler.
Jan 02, 2009 | Saeco Magic De Luxe Espresso Machine
Hot water won't flow into machine
You most likely need to prime the brew head. Follow the instructions in the owner's manual. To prime the brew head, you'll need to put run the machine without coffee until water starts flowing. One water flows, the brew head is primed and the machine is ready for normal use. You'll need to do this every time you run out of water. Regards, Denis
Oct 09, 2007 | Breville ESP8XL Espresso Machine
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
1,009 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
