Question about Canon imagePROGRAF iPF8000 Printer
IPF8000 PLOTER Error code E161 403E appears which i believe is a printhead problem, but I cant access the printheads as with this code showing i cant access any menu or any other option
  • aaron_noe Jun 18, 2008
  • Repsol
    Repsol Apr 22, 2014
    How can do to service mode?
Please input servicemode and reset all iniatilize menü
Posted on Dec 27, 2010
This is a printhead error
Remove the Printhead(s), clean the contacts,and replace in printer . Run nozzle check and try to print.
If you are able to print a few pages then get the same error, the Printhead will need to be replaced.
Good luck
Jul 10, 2014 | Canon imagePROGRAF iPF8000 Printer
Error code 03130031 2618 print
The hardware error code indicates that a print head failure has been detected. Other possible causes of this error are a faulty cable connection to either one of the PCB's.
First try replacing the Print Heads and if the problem persist, re-seat the cabling to the Relay PCB and the Carriage Unit PCB.
Since you are unable to access service mode, you will need to ignore the normal print head replacement procedure and replace the printheads whilst the plotter is turned off.
The plotter will need to be disassembled to access the print head.
See the following service manual for a detailed guide:
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Canon IPF 710 with error code E161-403E, abnormally high printhead temperature how do I clear/remedy it?
The error apeared when i stated to print !
How to solve it.
It is about 6 month since we started to use your product.
Apr 22, 2010 | Canon imagePROGRAF iPF8000 Printer
Printer wont copy error code 3802
Hi,error 3802 Means Printhead Failure
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it again for (5x)
And if the problem still there,
i will suggest you contact their customer care for further assistance.
Apr 16, 2010 | Office Equipment & Supplies
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
What is error code 3802
"Printhead Failure" (error code 3802)
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
IPF610 Canon "Print head needs cleaning"
I've had the same problem, and finally after hours of frustration, got Canon to provide a new PrintHead at no charge
Jun 02, 2009 | Canon imagePROGRAF iPF8000 Printer
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Canon ipf 8000 Error Code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Feb 21, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon ipf8000 error code
Hold down the roll/media button and the info button while turning on, wait about 10 seconds and release roll/info buttons. You should get an S in the upper right corner. That puts you in service mode. Push menu then scroll down to maintenance then right arrow to head replacement. To get out of service mode turn off.
Jan 04, 2008 | Canon imagePROGRAF iPF8000 Printer
Canon imagePROGRAF  iPF8000 Printer Logo
1,855 people viewed this question
old marine
old marine
