Question about ASUS V8420/Deluxe (128 MB) Graphic Card
I need the driver of asus v8420 delux card for windows 7
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Is there a driver for
No. Drivers for this card were released up to XP.
This card is built on an NVidia GeForce 8 series chip. You can try the latest driver pack for GEForce 8, I don't know if it will work.
Here link.
Regards.
Posted on Nov 09, 2010
Diasble audio
Just install the card as normal and plug any audio jack into the external audio card, windows 7 will automatically install the card
Mar 24, 2014 | ASUS P5GDC Deluxe Motherboard
Is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
Is there a driver for V8420 Delux Graphic Card for windows 7 ?
Here link.
Regards.
Nov 09, 2010 | ASUS V8420/Deluxe (128 MB) Graphic Card
Need graphic card that will work windows 7 windows aero on this motherboard?
aero needs dx10;your mb has only an agp 8x port and no video card with agp port don't have dx10 driver.
Apr 21, 2010 | ASUS P4C800 Deluxe Motherboard
ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
Jan 28, 2010 | ASUS P5GD2 Deluxe Motherboard
P5ad2-delux
This is because the sound driver achitecture does not fit with operating system of windows 7. Search for the a sound driver that will be compatible with windows 7, that will be found in the website of the motherboard brand.
Oct 15, 2009 | ASUS P5AD2-E Deluxe Motherboard
Mafia
Hi!
Well, I think this depends on the nature of the Game you playing. I suggest that you open any window or little application like notepad before you start the game, then try what you want to!
I hope it works!
Oct 31, 2008 | ASUS V8420/Deluxe (128 MB) Graphic Card
Defect ASUS V8420 ?
I don't understand, please explain more:
0) What kind of a monitor is it ?
1) If the monitor is NOT plugged into a working video card,
it should blank out or display some sort of a
"NO SYNC" or "NO SIGNAL" or "UNPLUGGED" warning.
The power light may also flash or show a different color.
2) If the monitor is plugged into a working video card,
it should wake up from the inactive power-saving mode
and display the desktop.
3) If the video card is malfunctioning, or if the windows
video settings are set outside of the monitor's sync limits,
the monitor may turn off or display a warning message,
such as:
No sync, Out of range ... etc.
4) The repair situation (3), reboot windows into
safe mode:
a) Press Hardware Reset
b) After the power-on self-test (POST) and memory check
press and hold the F8 Key
c) Select Safe mode
d) Login to windows at low resolution
e) Right-click on the desktop, chose:
Properties -> Settings -> Set the correct resolution, apply
Click advanced -> monitor -> set the correct refresh rate.
Reboot normally
Hope this helps
Martin
PS, some monitors have dual inputs: VGA or DVI
make sure the correct input is selected, depending
on your cable (VGA is a 15 pin "D" connector,
DVI is a larger connector with many more FLAT pins)
Also some video cards have multiple outputs, which are
activated only if a correct monitor is attached BEFORE
reset.
Apr 22, 2008 | ASUS V8420/TD Graphic Card
ASUS V8420/Deluxe (128 MB) Graphic Card Logo
328 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
