Question about Ovens
SCHOLTES CP756G on the display it says and blinks ER08
I'm asking about a cooker NOT a refrigerator!!
Good Morning Clare:
Now that we know,
Here's a link that may help you.
http://www.scholtes.com/_pdf/booklets/04/10/19508203300_UK.pdf
cheers.
Jun 17, 2016 | Ovens
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Scholtes FE46. We have no timer lights but do have temp and function lights. The oven won't unlock. Please help!
try rebooting; unplug or switch off the circuit breaker for 90 seconds
I have a scholtes 336 oven and it is locked!!! Help! Please!
Go on line with Schloss Ovens and request technical assistance giving your model number. I do not believe that there is any lock, per say, but something is jammed in the door that is holding it or it has a magnetic safety lock on the door that could be deactivated if you ynplug the unit...Good Luck!
Dec 28, 2012 | Ovens
Ariston FZ 970 CI IX The display is flashing Er 08. Can I repair this, cooking tonight John
Hi, does anyone know how to fix the problem when my ariston oven display appear Er08, thanks to advise asap!!! cheers
Nov 04, 2010 | Ovens
We have a scholtes oven, we are in france, we don't know the model, child lock is on and we can't unlock it/open door
we had the same problem just now and we solved it.
Our model is a "Fi 466 S" that has three knobs.
Just push all of them at once, which makes the "loughing lock"-display go away. And then press just the middle one for a time. That unlocks the oven.
Hope to be of help.
Oct 14, 2010 | Ovens
My stove works but it wont stop beeping
My scholtes cook top tig 664 won't stop beeping... Coming close to using a hammer! Help!
Oct 04, 2010 | Kenmore Ovens
What does ER08 mean
Hi, It indicates an overheated pcb board. This is a job for Creda as there are various causes and you could be buying expensive parts for nothing! :(
Jun 25, 2009 | Creda Ovens
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Ovens Logo
164 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
