Question about Kitchen Ranges
Trouble with a refrigerator side by side Amana Model # ARS2665AB. The unit stopped cooling and defrosted itself. When I turn it on the cooling fan goes on as do all the inside lights when the door is open. The compressor does not seem to run but then it gets very hot, and not cooling. Please advise Thank you.
  • Kitchen Ranges Master
  • 22,326 Answers
Classic symptoms the compressor motor has packed up and you need a new compressor ,so see if you find a local repair man recommended by friends or neighbours to change it for you ,as it does require special tools to change and re gas .
Posted on Nov 13, 2010
My Black Amana sxs Model SCD25JPW Fridge isn't cooling. Both sides are hot
OK, lets try a couple of things before you run out and buy a new unit. On that unit I believe the defrost thermostat is on the front bottom of the unit. Turn the little dial til it clicks and tell me if the unit kicks on.
Nov 30, 2012 | Amana ABB1921DE Bottom Freezer...
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Warm refrigerator and freezer
May be a bad defrost timer and the evaporater is froze up with ice. Clean dust buildup from the condenser under or behind the unit. Always give the model number
May 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
On an Amana ARS2661BS Unit does not cool on either side
Pull it away from the wall and remove the cover the covers the compressor. Unplug and tell me if the compressor is too hot to touch or if running or any signs of life. If not running and cool I want plug it back in, and open the fresh food door and and look for a hole in the control panel where you adjust temperatures. The opening is about the size of a pencil eraser. Sometimes this hole is covered by a plastic plug. Stick a small flathead screwdriver slowly clockwise until the compressor restarts. If this works the refrigerator needs a new defrost timer. Sometimes the defrost timer will stick in defrost and stop. Let me know, Thanks Sea Breeze
Jul 21, 2009 | Amana ARS2661BS Side by Side Refrigerator
Amana Fridge that won't keep cooling.
Inside your refrigerator fresh food compartment and behind the control panel is a Adaptive Defrost Board this could be the problem or the start relay and start capacitor located on the compressor. I would unplug and examine the defrost board first to see if it looks abnormal. Second I would replace the parts mentioned at the compressor if the Adaptive Defrost Board looks ok. Below is a link that you enter your model number in the model parts search feature. The part number for the Adaptive Defrost is 611005988
Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 28, 2009 | Amana DRSE663B Side by Side Refrigerator
Freezer problem
Have you checked the Heater element for the defrost to see if it's good? It sounds like the coils inside your freezer are freezing over into a solid block of ice which in turn will cause it to stop cooling.....efficiently. When you leave the unit unplugged, it gives the unit a chance to thaw and it work properly until the coils freeze over again. If heater is not the problem then Defrost Thermostat probably is. Both located in back of Freezer.
Nov 23, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fridge and freezer not cooling properly!
Sounds like a problem with defrost system , It could be one of there components , timer, heater, or defrost thermostat. try advancing the timer, down at the lower area behind the grill. with a screw driver by putting it into the dial advance and turn it till it clicks and the unit shuts off. now you should see red glow at bottom of back panel in freezer or here sizzling . if this does not happen then it will be the heater or the thermostat.
Apr 27, 2017 | Amana 22.6 cu. ft. Side-By-Side...
Amana SXD23VE quit cooling 3rd time
wel there are 2 thermostats in this unit, a defrost thermostat(very common to go bad) but would mainly affect refig sect and the freezer only slightly, the other is a cold control thermo affecting both freezer and refrig, if this goes bad you get NO cooling, looking at the diagram for the refrig it has a defrost timer under the righthand side of the kickplate, i would try advancing the timer, with a screw driver you can manual turn the plastic gear on the timer( i believe on yours its problaby a pink knob. its possible that the timer has gone bad and the unit is stuck in a defrost mode, try turning it ever so slightly, youll hear it "clicking" as you do , it should "snap" into arun mode and everthy kick on for it is stuck in defrost(worth a try anyway)
Oct 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana sxd524ve
why did you turn off in the first place??? to defrost ice off back wall??? if so sounds like you ahce a bad defrost thermostat. (evaporator fan get power from runnig through thermo. and when the thermo goes bad the unit stops cooling correctly because of the massive amount of ice that buildsaround the coil
Nov 29, 2007 | Amana SXD524VW Side by Side Refrigerator
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
